Large fonts with I2C interface to 1602 LCD
I had my project working and then decided what they hey I’d add the new I2C board I have. After interfacing it, the large fonts do not sow up, just garbage character, all the same but garbage. I took the old code and just added where I needed to for the I2C interface to the LCD.
Can anyone tell me what is wrong or if you can do this??
The I2C board uses the 8574 chip to do it’s work.
Thank you.
const int analogInPin = A0;  // Analog input pin that the potentiometer is attached to
int sensorValue = 0;        // value read from the pot
int outputValue = 0; // value output to the PWM (analog out)
//char outputValueChar[5];
int hundreds;
int tens;
int ones;
#include <Wire.h>
#include <LCD.h>
#define I2C_ADDR    0x27 // <<----- Add your address here.  Find it from I2C Scanner
#define BACKLIGHT_PIN     3
#define En_pin  2
#define Rw_pin  1
#define Rs_pin  0
#define D4_pin  4
#define D5_pin  5
#define D6_pin  6
#define D7_pin  7
LiquidCrystal_I2C	lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin);
// the 8 arrays that form each segment of the custom numbers
byte LT[8] =
  B00111,
  B01111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111
byte UB[8] =
  B11111, // was 11111
  B11111,
  B11111,
  B00000,
  B00000,
  B00000,
  B00000,
  B00000
byte RT[8] =
  B11100,
  B11110,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111
byte LL[8] =
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B01111,
  B00111
byte LB[8] =
  B00000,
  B00000,
  B00000,
  B00000,
  B00000,
  B11111,
  B11111,
  B11111
byte LR[8] =
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11110,
  B11100
byte UMB[8] =
  B11111,
  B11111,
  B11111,
  B00000,
  B00000,
  B00000,
  B11111,
  B11111
byte LMB[8] =
  B11111,
  B00000,
  B00000,
  B00000,
  B00000,
  B11111,
  B11111,
  B11111
// loop counter
int x = 0;
  // assignes each segment a write number
  lcd.createChar(0,LT);
  lcd.createChar(1,UB);
  lcd.createChar(2,RT);
  lcd.createChar(3,LL);
  lcd.createChar(4,LB);
  lcd.createChar(5,LR);
  lcd.createChar(6,UMB);
  lcd.createChar(7,LMB);
  // sets the LCD's rows and colums:
  lcd.begin(16, 2);
  lcd.setBacklightPin(BACKLIGHT_PIN,POSITIVE);
  lcd.setBacklight(HIGH);
void custom0()
{ // uses segments to build the number 0
  lcd.setCursor(x, 0); // set cursor to column 0, line 0 (first row)
  lcd.write((byte)0);  // call each segment to create
  lcd.write(1);  // top half of the number
  lcd.write(2);
  lcd.setCursor(x, 1); // set cursor to colum 0, line 1 (second row)
  lcd.write(3);  // call each segment to create
  lcd.write(4);  // bottom half of the number
  lcd.write(5);
void custom1()
  lcd.setCursor(x+1,0);
  //lcd.write(1);
  lcd.write(2);
  lcd.setCursor(x+1,1);
  lcd.write(5);
void custom2()
  lcd.setCursor(x,0);
  lcd.write(6);
  lcd.write(6);
  lcd.write(2);
  lcd.write(3);
  lcd.write(7);
  lcd.write(7);
void custom3()
  lcd.setCursor(x,0);
  lcd.write(6);
  lcd.write(6);
  lcd.write(2);
  lcd.write(7);
  lcd.write(7);
  lcd.write(5);
void custom4()
  lcd.setCursor(x,0);
  lcd.write(3);
  lcd.write(4);
  lcd.write(2);
  lcd.setCursor(x+2, 1);
  lcd.write(5);
void custom5()
  lcd.setCursor(x,0);
  lcd.write((byte)0);
  lcd.write(6);
  lcd.write(6);
  lcd.write(7);
  lcd.write(7);
  lcd.write(5);
void custom6()
  lcd.setCursor(x,0);
  lcd.write((byte)0);
  lcd.write(6);
  lcd.write(6);
  lcd.write(3);
  lcd.write(7);
  lcd.write(5);
void custom7()
  lcd.setCursor(x,0);
  lcd.write(1);
  lcd.write(1);
  lcd.write(2);
  lcd.setCursor(x+1, 1);
  lcd.write((byte)0);
void custom8()
  lcd.setCursor(x,0);
  lcd.write((byte)0);
  lcd.write(6);
  lcd.write(2);
  lcd.write(3);
  lcd.write(7);
  lcd.write(5);
void custom9()
  lcd.setCursor(x,0);
  lcd.write((byte)0);
  lcd.write(6);
  lcd.write(2);
  lcd.write(5);
  // read the analog in value:
  sensorValue = analogRead(analogInPin);
  // map it to the range of the analog out:
  outputValue = map(sensorValue, 0, 1023, 0, 360);
  // print the results to the serial monitor:
  Serial.print("sensor = " );
  Serial.print(sensorValue);
  Serial.print("\t output = ");
  Serial.println(outputValue);
  //String stringOne =  String(outputValue);
  // prints the value of outputValue
  //Serial.print("Output value string is ");
  //Serial.println(stringOne);
  x=0;
  hundreds = outputValue /100;
  //Serial.print(hundreds);
  //delay(500);
  switch (hundreds) {
    case 3:
      custom3();
  case 2:
    custom2();
  case 1:
   custom1();
  case 0:
    custom0();
  tens=outputValue /10;
  tens=tens%10;
  //Serial.println(tens);
  switch (tens) {
    case 9:
      x=x+3;
      custom9();
     case 8:
     x=x+3;
     custom8();
     case 7:
     x=x+3;
     custom7();
     case 6:
     x=x+3;
     custom6();
     case 5:
     x=x+3;
     custom5();
     case 4:
     x=x+3;
     custom4();
     case 3:
     x=x+3;
     custom3();
     case 2:
     x=x+3;
     custom2();
     case 1:
     x=x+3;
     custom1();
    // if (outputValue<10)
     //case 0:
   //  x=x+3;
   //  custom0();
   //  break;
    case 0:
    x=x+3;
    custom0();
  ones=outputValue%10;
  //ones=ones%100;
 // Serial.println(ones);
    switch (ones) {
    case 9:
      x=x+3;
      custom9();
     case 8:
     x=x+3;
     custom8();
     case 7:
     x=x+3;
     custom7();
     case 6:
     x=x+3;
     custom6();
     case 5:
     x=x+3;
     custom5();
     case 4:
     x=x+3;
     custom4();
     case 3:
     x=x+3;
     custom3();
     case 2:
     x=x+3;
     custom2();
     case 1:
     x=x+3;
     custom1();
     case 0:
     x=x+3;
     custom0();
  delay(200);
  lcd.clear();
  lcd.setCursor(1,12);
  lcd.write("        Degrees");
Does the backlight and a simple "hello world" work? i.e. if you print some thing simple before the large font stuff, does that work?
When adding an i2c backpack, I've seen 2 main problems that people have encountered. - Soldering the backpack on backwards/upsidedown (means pin 1 vs pin 16 is backwards) - getting the constructor incorrect.
Usually it is the constructor that is incorrect. It might be the i2c address, or it could be the pin mapping used in the constructor does not match what is used by the i2c backpack (different boards using different pin mappings between the lcd and the PCF8574 chip)
Are you sure that your your backpack uses the pin mapping used in the constructor? The best way is get it correct is to either use the pin mappings provided by the vendor of the backpack, or ohm out the board to figure it out. If you can't do either of those, you could run the i2clcdguesser sketch I wrote. You can find a zip of it over in this thread: http://forum.arduino.cc/index.php?topic=157817.msg1235230#msg1235230
--- bill
