Hello, I have keypad with 98 buttons and 98 leds. Buttons connected as a matrix 14x7, leds as well. Led should be HIGH the appropriate pressed button.
I’m going to use Keyboard library MultiKey example as a core. This one:
#include <Keypad.h>
const byte ROWS = 4; //four rows
const byte COLS = 3; //three columns
char keys[ROWS][COLS] = {
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}
byte rowPins[ROWS] = {5, 4, 3, 2}; //connect to the row pinouts of the kpd
byte colPins[COLS] = {8, 7, 6}; //connect to the column pinouts of the kpd
Keypad kpd = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
unsigned long loopCount;
unsigned long startTime;
String msg;
loopCount = 0;
startTime = millis();
msg = "";
loopCount++;
if ( (millis()-startTime)>5000 ) {
Serial.print("Average loops per second = ");
Serial.println(loopCount/5);
loopCount = 0;
// Fills kpd.key[ ] array with up-to 10 active keys.
// Returns true if there are ANY active keys.
if (kpd.getKeys())
for (int i=0; i<LIST_MAX; i++) // Scan the whole key list.
if ( kpd.key[i].stateChanged ) // Only find keys that have changed state.
switch (kpd.key[i].kstate) { // Report active key state : IDLE, PRESSED, HOLD, or RELEASED
case PRESSED:
msg = " PRESSED.";
case HOLD:
msg = " HOLD.";
case RELEASED:
msg = " RELEASED.";
case IDLE:
msg = " IDLE.";
Serial.print("Key ");
Serial.print(kpd.key[i].kchar);
Serial.println(msg);
} // End loop
First question is how I can declare 98 keys? It seams that I haven’t enough unique symbols.
And the second one is how I can identify leds to its buttons? I have driver for leds, wich means that I need just send the Serial.print(“comand”); with current led witch should be HIGH for a 3 seconds.
Thanks!
