Large motor Project
Peoples,
I am new to Arduino and have been instructed this project be ran by Arduino so I am scrambling to put something together as I mostly work with only PLC`s , so far I have the motor driver and a Arduino uno R3.
THE PROJECT: 30 Dc 7.2v motors must be ran non stop using PWM @ 100% then dropping to 70% for varying times.
Obviously I can only run 2 motors per H-Bridge which is the Monster Motor Controller Shield For Arduino (14A, 5.5-16V) due to the max amp draw of the motor its self. I have found some code but all of them seem to use a Pot to adjust the PWM, See attached.
How to I go about changing it to just run at two predetermined preset PWM %`s continuously?
Any help with this is greatly appreciated.
poss code.txt (1.75 KB)
You need to look at how many of these H bridge circuits you can drive from an Arduino pin , whether or not you can use multiple digital output pins - within the constraints of what the Arduino can supply.
Software wise you just need to switch between the two PWM values using , say a digital
Input.
If your motors only run in one direction you could just drive multiples of them via a transistor connected to a digital
Output .
The “H” bridge is only needed if you want to reverse a motor.
The Analog outputs from the Arduino are in fact PWM signals , so you only need to do “analog write” with varying levels to give you the PWM signal to drive your circuit.
This might help too ( scroll down!)
hammy, Thanks for the help and info, I opted for the H bridges as these motors are high amperage didn't want to kill the Arduino.
You wont kill them driving them through the transistor - which is doing the work in controlling the motor curent with a small signal from the Arduino.
A “H” bridge I s essentially 4 transistors in a bridge arrangement that allows the motor to go forwards and backwards , if you don’t need that it’s a waste of cash . Follow my links , look at transistors as a switch for further info .
grumpymp05:
That's not a valid reason.
As hammy said, you only use a H-bridge if you also need to reverse the motors.
Wise to post a link to the motor before you order any parts.
And I think a 2-motor shield is a poor solution for 30 motors.
You will likely have connection problems even stacking two shields.
Leo..
30 motors, each with individual PWM control?
You're going to need an external PWM chip for that. Probably a few of those, in fact. For control, just use a logic level n-channel MOSFET, low side.
