Can somebody PLEASE cite a reference to measuring the weight of a vessel and the "life-critial" that keeps getting tossed around. not what one 'feels' concerned about, but some actual reference to regulations ? NFPA, Electrical Code, anything ?
I used to do explosion proof controls and the simple, and I mean SIMPLE, requirement was:
" IN THE PRESENCE OF ..... [ state here the hazzard ].....
working with Fortune 50 companies, we would just put the stuff in the closet down the hall, besides who in their right mind would put an electromagnetic relay or heater wires in an explosion rich atmosphere ? ( OK, Honeywell and Apollo-13, but that doesn't count)\
example :
NFPA 497. You'll find that in open areas, the Class 1, Division 1, area is limited to a distance 5' from the source. The Class 1, Division 2 area is limited to a distance of 10' from the source
The reason they called it the 'control room' and not the 'hazardous lab atmosphere room' was because THAT is the way it is done.
or :
Where Class I liquids are stored, handled, or dispensed, electrical wiring and electrical utilization equipment shall be designed and installed in accordance with the requirements for Class I, Division 1 or Division 2 classified locations, as set forth in 8.3.2 and in NFPA 70, National Electrical Code ." NFPA 30A 2015, 8.3.1
and yes, we put ground straps on anything and everything, even plastic sensors. one facility had a safety plackard : this facility has not had an explosive accident since 1937. (the day it was opened)
and, we had entire buildings built adjacent to the lab, with the walls solid reinforced concrete and a hinged roof for the release of pressure in the event of an explosion. other building had blow-out walls for the same purpose.
bottom line IT CAN BE DONE.
we brought the concerns up, the facility WILL REQUIRE code be met as would anyone with more than 2 years in training, ie : EVERYBODY ELSE involved in the engineering of the project.
we are 32 posts into warnings, at some point one has to say we warned the guy.
all we needed to say is :
BEFORE YOU ATTEMPT to GO NEAR the thing, HIRE A PROFESSIONAL that knows the code and laws so you don't cause problems. NEVER rely on a web forum for advice on safety or the use of anything that might be unsafe.
we are NOT LICENSED and have NO rating to advise you on the safety issues, we are a hobby group and can only advise you on how we would do it with hobby parts and supplies in a hobby way, in a hobby environment. if you are trying to copy a product or system, SEEK OUT PROFESSIONALS who are licensed in that area for your own protection as well as the protection of others.
