Large Servo Motor Project Help
Hello everyone;
Im new to Servo Projects hence sorry if this is too basic.
Im supposed to use Servo motor; here are the equipments i got:
Servo Motor S80-M02430
Pn: 0.75 KW Tn: 2.4 N.m
In:3A Ip65
HNC AUTOMATION
DRINO MOTOR DRIVER
Model: DNS1-0R8FL
POWER: 0.8 KW
INPUT: 3PH AC 220V 50Hz/60Hz
OUTPUT: 3PH AC 220V 4.5A
SHENZHEN Drino Electric
Arduino UNO
I only got these equipment and i don't have a manual. How should i pursue this project i don't know how to connect properly these devices especially Arduino and driver. Can anyone basically explain how should i connect Arduino and this driver how to supply power?
Thank you very much in advance
PS: I put pics of driver and motor to attachment
First get the users manual for the things. If there isn't one or its only in chinese, you have a problem, and
a little guess work may be needed. The description of the driver suggests both a +/-10V analog speed input
and step/direction (stepper-driver-style) digital input for positioning control.
Good clear photos of all the connectors on the driver and its front-panel would be useful.
[BTW that's a small servo motor. Large ones are real beasts]
The setup i have is already supplied with necessary power, can i just connect the driver to arduino directly and use the servo library, or i need to somehow amplify the arduino control signal before connecting to driver
