Largest number that Arduino can process?
If i have a signed int 'val' and 'total' is an unsigned long and execute this in the arduino:
if (total - (val*4939)) {...}
What happens if val4939 is greater than 65536? Does it not matter because it's happening in the ALU not in the memory location?
Also what happens if the val
4939 comes out negative but total is unsigned?
I'm not sure how I'm supposed to think about it.
Thanks!
What happens if val*4939 is greater than 65536?
The register being used to hold the result will overflow. You need to tell the compiler to use a larger register, by declaring val as long or appending UL to the constant so that the compiler knows to use a larger register.
Also what happens if the val*4939 comes out negative but total is unsigned?
Mixed mode comparisons are a disaster waiting to happen. Don't do it. Type or cast variables yourself so that you KNOW what will happen.
// Range LONG_LONG_MIN:  -9223372036854775808
// Range LONG_LONG_MAX:   9223372036854775807
// Range ULONG_LONG_MAX: 18446744073709551615
// IMPORTANT NOTE - Assigning values requires suffix 'LL' for signed values and 'ULL' for unsigned values
long long           n_max  =   9223372036854775807LL;
long long           n_min  =  -9223372036854775808LL;
unsigned long long  n_umax =  18446744073709551615ULL;
Although there doesn't appear to be a wy for 'Serial.print' to display them.
you can process them in a loop, 1 (or more) digits per iteration...
Note: long long math is sssllllloooooowwww
Furthermore, recently Nick Gammon ported a bigNumber Class, see - http://arduino.cc/forum/index.php/topic,85692.0.html -
that can even process larger numbers until it runs out of RAM ...
