Laser alarm with SMS notifcation
Hy guys,
I am working on a project that involves sending a SMS whenever the alarm turns on. I am using Arduino UNO and aGSM Shield
The problem that I am having is sending the SMS. If I just run an ordinary SendSMS code then I get the message. But for my project, it won't send.
So the logic behind what I want to do is this:
Only when GSM is initialized then you can go ahead and arm the system. Then, only after the system is armed(by the press of a button) if you block the laser, the alarm will go on and send SMS notification. Otherwise do nothing.
I've done everything but manage to send the SMS notification.
My code:
 // check to see if GSM initialized
  if (neconectat)
 //check to see if I pressed the button to arm the system
  state = digitalRead(senzorArmare);
  if (state != lastState)
    if (state == HIGH)
      if (armat == HIGH) armat = LOW;
      else armat = HIGH;
    lastState = state;
  //next time the button is pressed the system will be disarmed
  if (armat==HIGH )
    digitalWrite(indicatorArmare,HIGH); // indicatorArmare is a led that turns on when button is pressed
    analogValue=analogRead(LDR); //read value from the LDR
    delay(50);
    Serial.println(analogValue); // just to see on serialMonitor the valuea red
    if (analogValue>20 ) // if beam is broken
       digitalWrite(ledAlarma,LOW); //ledAlarm is a led that turns on when beam is broken
       digitalWrite(speaker,LOW);
       digitalWrite(ledAlarma,HIGH);
       digitalWrite(speaker,HIGH);
       Serial.println("ALARMA!");
       ok=true; // 1st ok = false - it turns on only when beam is broken
    digitalWrite(indicatorArmare,LOW);
 if (ok) then trimiteMesaj;
 // send the message function
void trimiteMesaj(){
  sms.beginSMS(charbuffer); // charbuffer - my phone nr
  sms.print(mesaj); //mesaj - the message to send
  sms.endSMS();
  Serial.println("\nCOMPLETE!\n");  //just to see if the system runs this function
Ok so when I interrupt the beam the system holds ( I see the "ALARMA!" message on serialMonitor but nothing else happens). After 3-4 seconds COMPLETE! appears on the serialMonitor but the message is not sent.
PS: The GSM Shield is connected to a recommaned power supply.
Thank you,
Vlad C.
