Laser detection, Transistor problem...
Hello all,
I have made this circuit (below) for laser detection in my work with photodiode in (X1-1 ; X1-2) and Arduino. Everything works perfectly.
For technical reasons, I wish away the photodiode from the board (arround 1.5 m). But when I put a cable (02x0.4mm) greater than 30 cm between the photodiode and the board , transistors engage, as if there were laser detection.
I try to put variable resistors between the first transistor, but it has nothing do …
any help would be welcome, as I am completely stuck
Br :wink:
You need shielded coax cable to the diode, you are just picking up RFI.
[ well probably. Another possibility is oscillation. ]
Try some different valued capacitors across the input ex. .001 etc.
Also consider adding some decoupling for the power supply.
MarkT:
Indeed, it is quite logical explanation for coax ... I will try tomorow . What do you mean with oscillation?
LarryD:
I try 0-100K Ohm variable resistor nothing change..
FYI Voltage input is 12v, 4A. (Laser photodiode, support more than 40V)
By the way thank you for the reasonable sized images, wish others would do so.
azizth:
MarkT:
You might have turned the circuit into an oscillator since it uses a feedback network
and the input cable adds capacitance changing the phase response of the feedback.
I just test a Coax cable , no more problems .. Thank you!
You think a Cat.5 FTP network cable can also do the trick? Because I would put several photodiode in parallel.
Unfortunatly, after some test, Coax cable is better but the system remains unstable :~
The Circuit is very sensitive, because I only have to touch the sheath of the cable to trigger the transistors.
what I need to change to reduce this sensitivity?
Maybe the first capacitor of 10nF to 1?F to filter more?
Thank you
