Hello to everyone ,
I am atemping to use the GY-53 sensor but I am not sure if I can use it using the VL53L0X library since the GY-53 has 12 pines instead of 6 as the Adafruit sensor has (in my location I was not able to buy the Adafruit sensor).
Has someone used the GY-53 sensor? I would appreciate if you can confirm that the library works with the GY5-3 sensor and also if it's required a different circuit to use the I2C protocol comunication.
Thanks in advance
