Laser-fototransistor sensor
hello,
SOmebody know why my code dosen’t work ?
#include <AccelStepper.h>
AccelStepper stepper1(AccelStepper::FULL4WIRE, 4, 5, 6, 7);
#define sensor 2
byte KORAK;
   pinMode(sensor, INPUT);
   stepper1.setMaxSpeed(150.0);
   stepper1.setAcceleration(150.0);
   stepperHome();
  stepper1.moveTo(20000); //da dođe do sensora
  stepper1.runToPosition();
  delay(2000);
void stepperHome()
      KORAK = digitalRead(sensor);
      while (KORAK = HIGH)
        stepper1.run();
        KORAK=digitalRead(sensor);
      stepper1.setCurrentPosition(0);
connection schema- 5V-RESISTOR-LASER-GND
5V-FOTOTRANSISTOR-RESISTOR-ARDUINO PIN 3-GND
tnx
Your first obvious blunder is here:
while (KORAK == HIGH) still fototransistor dosent work
Phototransistor wired the correct way around?
Start by making sure you read the phototransistor properly:
loop() {
  Serial.println(digitalRead(sensor));
you should get a row of 1s and 0s depending on whether the phototransistor is conducting or not.
