Hi All,
I'm wanting to create my own laser position detector based on an Circuit Cellar article from 2003 by Roger Johnson and Chris Lentz. The article can be found here: Article Link
In the article they provide the circuit diagram. Now I am hoping that I can replace the micro controller they use with an Arduino Nano and connect straight to the MCP3204 using SPI on the Nano. I have attached an image for the proposed changes.
Do you guys think this will work? Or are there further changes required?
Thanks for your help
The only thing you change is the uC. Where's the problem?
There isn't a problem, I was asking if it is as easy as just changing the microcontroller.
Thanks
What PSD are you going to use? They seem to run from $200 to $$$$$
I'm guessing you will have to re-write the software. Have you been able to download it from their FTP server? I just tried (ftp://ftp.circuitcellar.com/pub/Circuit_Cellar/2003/152/) and am stuck on "Connecting...".
The site went offline ages ago, but you might have luck with archive.org. Anyway, no rocket science hidden there, just 4x ADC values. Anyway, the cheeper way is to use a camera nowadays.
