I have made an arduino programm with a seven segment display and a button. When I press on the button the display counts up. But for my project I want to do it whit a laser receiver. If the laser receiver receives light, it has to count up. I also already have a programm for the laser receiver but how can i put these programms togheter. Could anyone help?
These are my programms…
1)Laser receiver
int licht;
Serial.begin (9600);
pinMode (13,OUTPUT);
licht=analogRead(0);
Serial.println(licht);
if (licht<940) {
digitalWrite(13,HIGH);
else {
digitalWrite (13,LOW);
delay(100);
- Display + button
const int a = 2;
const int b = 3;
const int c = 4;
const int d = 5;
const int e = 6;
const int f = 7;
const int g = 8;
const int drukknop = 9;
int ktnu = 0;
int knopteller = 0;
int ktvorige= 0;
boolean zero(){
digitalWrite(a, HIGH);
digitalWrite(b, HIGH);
digitalWrite(c, HIGH);
digitalWrite(d, HIGH);
digitalWrite(e, HIGH);
digitalWrite(f, HIGH);
digitalWrite(g, LOW);
return true;}
boolean one(){
digitalWrite(a, LOW);
digitalWrite(d, LOW);
digitalWrite(e, LOW);
digitalWrite(f, LOW);
return true;}
boolean two(){
digitalWrite(c, LOW);
digitalWrite(g, HIGH);
return true;}
boolean three(){
return true;}
boolean four(){
return true;}
boolean five(){
digitalWrite(b, LOW);
return true;}
boolean six(){
return true;}
boolean seven(){
return true;}
boolean eight(){
return true;}
boolean nine(){
return true;}
boolean leeg(){
return true;}
void setup(){
pinMode(a, OUTPUT);
pinMode(b, OUTPUT);
pinMode(c, OUTPUT);
pinMode(d, OUTPUT);
pinMode(e, OUTPUT);
pinMode(f, OUTPUT);
pinMode(g, OUTPUT);
pinMode(drukknop, INPUT);
void loop(){
ktnu = digitalRead(drukknop);
if (ktnu != ktvorige) {
if (ktnu == HIGH) {
knopteller++;
Serial.println(“aan”);
Serial.print("aantal keren gedrukt: ");
Serial.println(knopteller);
Serial.println(“uit”);
delay(200);
int t = 1000;
switch (knopteller){
case 0: zero(); break;
case 1: one(); break;
case 2: two(); break;
case 3: three(); break;
case 4: four(); break;
case 5: five(); break;
case 6: six(); break;
case 7: seven(); break;
case 8: eight(); break;
case 9: nine(); break;
case 10: zero(); break;
Thank you
