I am currently designing a project for a laser gun and I have a few questions on how to go about doing it safely.
I would like to mount a laser on the gun where the beam is visible at night and under normal atmospheric conditions (no fog, etc). However, I would also like the laser to be safe to view for short exposure or accidental exposure.
Looking at laser safety info, the laser should be at most class 2M, however, I may be wrong.
My question is - what laser specs (wavelength, mW, color, etc.) will create a visible laser beam, but also stay within safe viewing conditions?
What is the end requirement of the laser gun? is it to be used as a pointer to show where something is?
Lasers are fun but dangerous, depending on what you want to achieve you may be able to get something on ebay for a few dollars.
Shows usually depend on fog machines or whatever the audience is smoking so that there is something in the air to make the beam visible. Otherwise there is no way a laser beam could travel to the moon and back.
If you buy a laser from a no-name company on Ebay or Aliexpress there is no guarantee that the output power matches the spec. For example if you buy a 1mw laser, it may actually be a 5mw laser that the supplier got at a cheap bulk price and has rebadged as a 1mw laser.
Unless you have suitable test equipment you'll never know that you bought something that is dangerous.
That does depend on particles in the air, but on a clear night there is still enough "stuff" in the air to see a powerful-enough beam.
At rock shows they use a haze machine or fog machine to enhance light beams & laser beams. (If you're not seeing fog but you're seeing the beams, it's a haze machine.) At outdoor shows, of course they can't put fog/haze high into the sky, so you're seeing whatever is in the air naturally.
...I have a video of a Pink Floyd show and in the beginning there is a shot of someone lighting a cigarette with a laser!
