Hello Everyone,
Although I have done many projects with Arduino, I consider myself a newbie still so forgive me if I don't understand everything This is also my very first post ... But anyways I have existing Phoenix LTX guns as seen on this website. http://www.ggaub.com/ltag/images/equipment/phoenix-ltx-pr-shot_big.jpg
I want to be able to capture the signal being output from the guns, recreate the signal on the Arduino, and finally output it to "tag" a different gun.
So far I have created many different codes so I am not sure which to put up. So far I have two different Arduino set-ups; a receiver and emitter. For my receiver setup, I broke open an old computer remote receiver and put the npn transistor looking detector in a basic 5V or GND switch setup. 5V goes to the collector, I pull out the voltage at the emitter side which also connects to an 11k resistor going to ground. Using this I was able to get
The top graph is the incoming signal from the laser tag gun, and the bottom signal is my recreation of the signal using a bunch of delayMicroseconds() and digital writes. I noticed that these graphs match with previous work from a laser tag site. LTTO Signals
So my emitter setup results were seen in the graph above. My emitter setup is a High-Output Infrared 940nm wavelength LED connected in series through 200 Ohm resistor to a digital output pin. I would post the code, but it is honestly just a bunch of delayMicroseconds() with high and low digital writes. But I can't get the Arduino to "tag" the other gun.
I have read that you need to have a carrier frequency of 38kHz and I feel that this is the reason my setup isn't working. I have read many other posts about carrier frequency but I can't seem to get it to work using their methods of changing the clock timer and/or using tone(). I was wondering if you all had some guidance for me on how to go about doing this or if there could be anywhere else specifically that I have gone wrong.
Thanks
