Could someone please help me on coding this on two arduino/ genuino 101 boards. There is a picture attached displaying when all the components are
Arduino 1 is the master
Arduino 2 is the slave
Arduino 1 is connected to laser 1 and 2
Arduino 2 is connected to laser 3 and 4
If laser 1 is broken and then laser 2 then the lights trigger.
If laser 4 is broken and then laser 3 then the lights trigger.
If laser 2 is broken and then laser 1 then the lights will not trigger.
If laser 3 is broken and then laser 4 then the lights will not trigger.
If both lasers 1 and 2 or both lasers 3 and 4 are triggered at the same time then the lights trigger- means a heavy flow of traffic, the same if all four lasers are triggered at the same time
Once triggered the light will turn from green to red and flash __ flashes per minute
The idea at the moment is to have ‘people on crossing’ integer which is added to when laser 1 is broken before 2 or laser 4 is broken before 3, and subtracted from when laser 2 is broken before 1 or laser 3 is broken before 4
Existing code:
//Setup for pins that measure the photoresitors attached to lasers.
const int sensorPin_1 = 1;
const int sensorPin_2 = 2;
const int sensorPin_3 = 3;
const int sensorPin_4 = 4;
//Setup for pins to control the colour of the leds
const int ledPinRed = 10;
const int ledPinGreen = 11;
// counter for the number of people on the crossing.
// Must equal zero for the light to be green.
int peopleOnCrossing = 0;
//Levels for Photoresistors - will also need mapping - see other file
int lightLevel_1, high_1 = 200, low_1 = 700;
int lightLevel_2, high_2 = 200, low_2 = 700;
int lightLevel_3, high_3 = 200, low_3 = 700;
int lightLevel_4, high_4 = 200, low_4 = 700;
//Boolean conditions for individual laser triggers
boolean laser1Triggered = false;
boolean laser2Triggered = false;
boolean laser3Triggered = false;
boolean laser4Triggered = false;
//Boolean conditions to determine if somebody has entered the crossing.
boolean enteredFrom1_2 = false;
boolean enteredFrom4_3 = false;
//Boolean conditions to determine if somebody has exited the crossing.
boolean exitFrom1_2 = false;
boolean exitFrom4_3 = false;
pinMode(ledPinRed, OUTPUT);
pinMode(ledPinGreen, OUTPUT);
//if the photoresistor gives a value of less than 700, the laser beam has been broken.
//the level of each photoresistor is being given by the lightLevel_1, 2, 3 and 4.
// The following analogRead functions are used to get a value from the photoresistor attached to each laser.
lightLevel_1 = analogRead(sensorPin_1);
lightLevel_2 = analogRead(sensorPin_2);
lightLevel_3 = analogRead(sensorPin_3);
lightLevel_4 = analogRead(sensorPin_4);
Serial.println(“lightLevel_1 =”); //Print the name of laser1 to the serial monitor
Serial.println(lightLevel_1); //Print the value of laser1 to the serial monitor
Serial.println(“lightLevel_2 =”); //Print the name of laser2 to the serial monitor
Serial.println(lightLevel_2); //Print the value of laser2 to the serial monitor
Serial.println(“lightLevel_3 =”); //Print the name of laser3 to the serial monitor
Serial.println(lightLevel_3); //Print the value of laser3 to the serial monitor
Serial.println(“lightLevel_4 =”); //Print the name of laser4 to the serial monitor
Serial.println(lightLevel_4); //Print the value of laser4 to the serial monitor
//check if any lasers have been triggered (write in a function)
if (lightLevel_1<700);
laser1Triggered = true;
if (lightLevel_2<700);
laser2Triggered = true;
if (lightLevel_3<700);
laser3Triggered = true;
if (lightLevel_4<700);
laser4Triggered = true;
// if laser 1 then laser 2 are broken, somebody has entered the left crossing
if(laser1Triggered && !laser2Triggered)
enteredFrom1_2 = true;
if(laser1Triggered && laser2Triggered && enteredFrom1_2)
peopleOnCrossing++;
//reset triggers
// if laser 2 and then laser 1 are broken, somebody has exited the left crossing
if(laser2Triggered && !laser1Triggered)
exitFrom1_2 = true;
if(laser1Triggered && laser2Triggered && exitFrom1_2)
peopleOnCrossing–;
//reset triggers
// if laser 4 then laser 3 are broken, somebody has entered the right crossing
if(laser4Triggered && !laser3Triggered)
enteredFrom4_3 = true;
if(laser4Triggered && laser3Triggered && enteredFrom4_3)
peopleOnCrossing++;
//reset triggers
// if laser 3 and then laser 4 are broken, somebody has exited the right crossing
if(laser3Triggered && !laser4Triggered)
exitFrom4_3 = true;
if(laser3Triggered && laser4Triggered && exitFrom4_3)
peopleOnCrossing–;
//Print the status of peopleOnCrossing to the serial monitor
Serial.print (“People on Crossing =”);
Serial.print (peopleOnCrossing);
//reset triggers
exitFrom4_3= false;
// control traffic lights
if(peopleOnCrossing > 0)
//change to red light
digitalWrite(ledPinGreen, LOW);
digitalWrite(ledPinRed, HIGH);
Serial.print (“I’m on red”);
//change to green light
digitalWrite (ledPinRed, LOW);
digitalWrite (ledPinGreen, HIGH);
Serial.print (“I’m on Green”);
