Hi guys, first post so go easy
Had my Arduino Uno for a few years now and not really decided on a use other then to play with. We'll i love my cars (Do all the work except MOT's my self) and i also love programming (its my job ) so combining them sound's brilliant.
I'm always tinkering with my suspension and steering and when i do more often then not my toe is out, see pic for non car people
So i want to build some form of rig that can be placed along the front surface of each wheel and measure the distance between both wheels left and right side. This should allow me to be able to calculate an angle of Toe in/out and either alter the Toe or just confirm i haven't sent it wildly out. Iv'e been doing this in the past with tape measures but that's tedious and prone to greater error.
Then could then be extended with a display and speaker where i could enter the degree of toe desired and it could beep to indicate if im adjusting it in the right direction and when im at the level desired.
From a programming point of view im quite happy with what i'd have to do, also from the fabrication side of things. My main concern (Which is why im asking advice on my project) is does the Arduino have sensor acurate enough to perform this task? The only sensors ive been able to find are Ultra Sonic and IR. Ultra sonic wont work as i need to measure distance between two specific fixed points. However the juries still out on the IR. I will be doing the work out side when using these so i don't know how well IR would work, also with the distance.
Thanks all for any advice and of cause ill report back with my progress as i build it (if its feasible)
