Hi
Newbie question. I want to make a guitar effects switching box. I have a background in BMS/PLC programming (logic block based) so I’m struggling with the base concepts of Arduino as my head is full of so called “Programming rules" that don’t apply here.
I have 4x momentary push button switches, used to switch channels Depending on what button is pushed it will lacth the two relays as per the attached table. It’s almost a binary converter. 1=00, 2=01, 3=10, 4=11
Obviously easy to turn an output on. But I don’t understand some control basics.
How do I make the relay latch in it’s open or closed position?
When I press another button to switch modes, will it override the previous command? Or do I have to initiate a reset of the previous latch each time a button is pressed? The latter sounds complex. As these buttons may be turned on in any order depending which effect I need.
Thanks, please let me know what else I need to provide.
For those wanting more details the Boss katana 50 uses a 3 pin (TRS - Tip, Ring, Sleeve) plug. Relay 1 is connected across the Ring & Sleeve; Relay 2 is connected across the Tip & Sleeve. Quite clever really.
Cheers
