My project is this: Get pixel data from the screen, send it to arduino as a string of rgb triplets, arduino parses the data and outputs it to the leds. Problem is, there is a latency between the moment something changes on the screen and the led updates accordingly. It is not a consistent lag though, sometimes a whole second, sometimes half a second or less.
I couldn’t find any solutions through preliminary searches on google or on the forums, hence this post.
Here is the python code
s = serial.Serial(9,57600, timeout=0.001) # opening the serial port
time.sleep(2)
px=ImageGrab.grab().load()
while(True):
time.sleep(0.01)
pixelValue=px[235,691]
if pixelValue[0]>pixelValue[2] and pixelValue[0]>pixelValue[1]:
pixelText='1,1,0'
elif pixelValue[1]>pixelValue[2] and pixelValue[1]>pixelValue[0]:
pixelText='1,0,1'
elif pixelValue[2]>pixelValue[1]and pixelValue[2]>pixelValue[0]:
pixelText='0,1,1'
else:
pixelText='1,1,1'
pixelArray=pixelText
for i in range (1,3):
pixelValue=px[235,691-(i*8)]
pixelText=',1,1,1'
pixelText=',1,0,1'
pixelText=',0,1,1'
else:
pixelText=',1,1,1'
pixelArray+=pixelText
pixelArray=pixelArray+'g'
s.write(pixelArray)
print(pixelArray)
print('\n')
Here is the arduino code
//Pin connected to ST_CP of 74HC595
int latchPin = 8;
//Pin connected to SH_CP of 74HC595
int clockPin = 12;
////Pin connected to DS of 74HC595
int dataPin = 11;
int temp;
//holders for infromation you're going to pass to shifting function
const int numRegisters=2;
int i,j;
byte dataArray[numRegisters+1];
//set pins to output because they are addressed in the main loop
pinMode(latchPin, OUTPUT);
Serial.begin(57600);
//Arduino doesn't seem to have a way to write binary straight into the code
//so these values are in HEX. Decimal would have been fine, too.
//function that blinks all the LEDs
//gets passed the number of blinks and the pause time
blinkAll_2Bytes(2,500);
for(i=0;i<numRegisters;i++)
dataArray[i]=0;
while (Serial.available() > 0) {
for(i=0;i<numRegisters;i++){
for(j=0;j<8;j++){
dataArray[i]+=Serial.parseInt()*(1<<(7-j));
//multiply the data coming in to convert binary to decimal
// look for the next valid integer in the incoming serial stream:
if (Serial.read() == 'g') {
//load the light sequence you want from array]
//ground latchPin and hold low for as long as you are transmitting
digitalWrite(latchPin, 0);
//move 'em out and reset the array
shiftOut(dataPin, clockPin, dataArray[i]);
//Serial.print(dataArray[i]);
//Serial.print('\n');
dataArray[i]=0;
//return the latch pin high to signal chip that it
//no longer needs to listen for information
digitalWrite(latchPin, 1);
//delay(300);
// the heart of the program
void shiftOut(int myDataPin, int myClockPin, byte myDataOut) {
// This shifts 8 bits out MSB first,
//on the rising edge of the clock,
//clock idles low
//internal function setup
int i=0;
int pinState;
pinMode(myClockPin, OUTPUT);
pinMode(myDataPin, OUTPUT);
//clear everything out just in case to
//prepare shift register for bit shifting
digitalWrite(myDataPin, 0);
digitalWrite(myClockPin, 0);
//for each bit in the byte myDataOut?
//NOTICE THAT WE ARE COUNTING DOWN in our for loop
//This means that %00000001 or "1" will go through such
//that it will be pin Q0 that lights.
for (i=7; i>=0; i--) {
//if the value passed to myDataOut and a bitmask result
// true then... so if we are at i=6 and our value is
// %11010100 it would the code compares it to %01000000
// and proceeds to set pinState to 1.
if ( myDataOut & (1<<i) ) {
pinState= 1;
else {
pinState= 0;
//Sets the pin to HIGH or LOW depending on pinState
digitalWrite(myDataPin, pinState);
//register shifts bits on upstroke of clock pin
digitalWrite(myClockPin, 1);
//zero the data pin after shift to prevent bleed through
//stop shifting
//blinks the whole register based on the number of times you want to
//blink "n" and the pause between them "d"
//starts with a moment of darkness to make sure the first blink
//has its full visual effect.
void blinkAll_2Bytes(int n, int d) {
shiftOut(dataPin, clockPin, 0);
delay(200);
for (int x = 0; x < n; x++) {
shiftOut(dataPin, clockPin, 255);
delay(d);
delay(d);
So, in my case, a valid string to send from python would be
1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1g
Also worthy of note is that I can see in the python shell that the program goes through the loop multiple times a second while showing the pixel values updating almost instantly, leading me to believe that the arduino or the serial comms is the source of the problem.
Thanks ahead of time!
