I was trying to create a lib file with some basic functions when something went wrong. Just FYI I clicked on Add Lib and then nothing worked. I tried to restart Arduino but now all I get is "launch4J" error. I tried to delete Arduino and all it's sub folder but windows reported it could not delete the folders. I see all my folders have the Read-only flag set, I can't reset them. In my arduino directory there is a folder named "Libraries". That folder contains 20 layers of folders named the same thing all appears to be empty. Can't delete them. Windows reports the source file names are larger than is supported by the file system.
Searching the forum I found the command to run debug and generate a report the following is a copy of that report:
CmdLine: C:\Users\PEH\Documents\Arduino\arduino-1.0.5\arduino.exe --l4j-debug
WOW64: yes
Working dir: C:\Users\PEH\Documents\Arduino\arduino-1.0.5.
Bundled JRE: java
Check launcher: C:\Users\PEH\Documents\Arduino\arduino-1.0.5\java\bin\javaw.exe (OK)
Add classpath: lib\pde.jar
Add classpath: lib\core.jar
Add classpath: lib\jna.jar
Add classpath: lib\ecj.jar
Add classpath: lib\RXTXcomm.jar
Launcher: C:\Users\PEH\Documents\Arduino\arduino-1.0.5\java\bin\javaw.exe
Launcher args: -Xms128m -Xmx128m -classpath "lib;C:\Users\PEH\Documents\Arduino\arduino-1.0.5\java\lib\tools.jar;lib\pde.jar;lib\core.jar;lib\jna.jar;lib\ecj.jar;lib\RXTXcomm.jar" processing.app.Base
Args length: 184/32768 chars
running windows 7
Any help, thanks
