LAUNCHING A ROCKET USING ARDUINO
Good morning,
I’d like to ask some questions regarding arduino coding. I got a project, specifically it is to open gate to launch a rocket and return it back to its original position and finally close the gate back.
I try to use Servo motor for the gate and it works but however, I don’t know how to launch the rocket (up and down). I got a 3 wire stepper motor (black, red and white). The problem is I don’t know how to code the stepper motor to work along with the servo and push button.
The mechanism is like this:
  1. Push button
  2. Gate opens
  3. Rocket launch
  4. Wait for 5 seconds
  5. Rocket return back
  6. Gate closed
Can you help me with this? I hope you can help me. Thank you so much.
This is the code that I recently used.
#include <Servo.h>;
// pushbutton pin
const int buttonPin = 8;
// servo pin
const int servoPin = 9;
Servo servo;
//create a variable to store a counter and set it to 0
int counter = 0;
servo.attach (servoPin);
// Set up the pushbutton pins to be an input:
pinMode(buttonPin, INPUT);
// local variable to hold the pushbutton states
int buttonState;
//read the digital state of buttonPin with digitalRead() function and store the //value in buttonState variable
buttonState = digitalRead(buttonPin);
//if the button is pressed increment counter and wait a tiny bit to give us some //time to release the button
if (buttonState == LOW) // light the LED
counter++;
delay(150);
if(counter == 0)
servo.write (20); // zero degrees
if(counter == 1)
servo.write(90);
//else reset the counter to 0 which resets thr servo to 0 degrees
counter = 0;
I am not sure what component you are calling a rocket. Do you have a link to it?
Next, please read the stickies above the forum and put your code into code tags.
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html .
Thanks… Tom… :slight_smile:
So… something like this?
What is the stepper motor for?
#include <Servo.h>
const byte LaunchPin = 2;
Servo servo;
int counter = 0;
const int GateOpen = 90;
const int GateClosed = 20;
  servo.write(GateClosed);  // Gate initially closed
  servo.attach(servoPin);
  pinMode(buttonPin, INPUT_PULLUP);
  // Make sure launch pin is LOW before it is set to OUTPUT
  digitalWrite(LaunchPin, LOW);
  pinMode(LaunchPin, OUTPUT);
  // 1. Push button
  if (digitalRead(buttonPin) == LOW)
    // 2. Gate opens
    servo.write(GateOpen);
    delay(500); // Give the gate plenty of time to open
    // 3. Rocket launch
    digitalWrite(LaunchPin, HIGH);
    delay(100);  // Give the rocket time to clear the pad
    // 4. Wait for 5 seconds
    delay(5000);
    // 5. Rocket return back
    // 6. Gate closed
    delay(500);  // Give the gate plenty of time to close
This must be a joke!
Paul
The stepper model is DS04-NFC. Actually there a rod that is attach to the stepper (so that when it rotates, the rod that is tied along with the rocket can drag the rocket upward and downward)
The rocket is actually a 3D Printed rocket.
johnwasser:
#include <Servo.h>
Servo servo;
int counter = 0;
  // 1. Push button
    // 2. Gate opens
    // 3. Rocket launch
    delay(5000);
    // 6. Gate closed
Can you post a picture of your project please, so we can see your component layout and see what your rocket is?
The servo is a continuous rotation type.
Thanks.. Tom.. :slight_smile:
NSR97:
A “DS04-NFC” is not a stepper. It is a “continuous rotation servo”, basically a geared-down motor.
To use it, connect it like another servo:
#include <Servo.h>
const byte RocketMotorPin = 2;
Servo GateServo;
Servo RocketMotor;  // Continuous Rotation Servo
const byte RocketUp = 70;  // Closer to 90 goes slower.  Closer to 0 goes faster.
const byte RocketStop = 90; // May need to be adjusted for your DS04-NFC
const byte RocketDown = 110; // Closer to 90 goes slower.  Closer to 180 goes faster.
  GateServo.write(GateClosed);  // Gate initially closed
  GateServo.attach(servoPin);
  RocketMotor.write(RocketStop);
  RocketMotor.attach(RocketMotorPin);
  // 1. Push button
    // 2. Gate opens
    GateServo.write(GateOpen);
    // 3. Rocket launch
    RocketMotor.write(RocketUp);
    delay(5000);  // Time for rocket to reach the top
    delay(5000);
    RocketMotor.write(RocketDown);
    delay(5000);  // Time for rocket to reach the bottom
    // 6. Gate closed
