Hi there, i am building an arduino lawn mower. I have 4 ultrasonic sensors hc-sr04, but only one is working. Can someone check what did i do wrong? my programming skills are not that great. thanks
#include <NewPing.h>
#include <Servo.h>
#include "U8glib.h"
#include <TimerOne.h>
Servo myservo;
int green;
#define s0 53
#define s1 52
#define s2 51
#define s3 50
#define sensorOut 49
#define TRIGGER_PIN 11
#define ECHO_PIN 10
#define MAX_DISTANCE 1000
#define TRIGGER_PIN 9
#define ECHO_PIN 8
#define TRIGGER_PIN 2
#define ECHO_PIN 3
#define TRIGGER_PIN 4
#define ECHO_PIN 7
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE);
U8GLIB_SSD1306_128X64 u8g(U8G_I2C_OPT_NONE); // VDD=5V GND=GND SCL=SCL SDA=SDA
NewPing sonar1(11, 10, 100);
NewPing sonar2(9, 8, 50);
NewPing sonar3(2, 3, 50);
NewPing sonar4(4, 7,50);
#define motor_aPin1 A0
#define motor_aPin2 A1
#define motor_bPin1 A2
#define motor_bPin2 A3
#define motor_aEnable 5
#define motor_bEnable 6
#define OB_range 30
int i=0, pos = 0,current_distance=0;
int range0=0, range30=0, range60=0, range85=0,range90=0,range95=0, range120=0, range150=0, range180=0 ;
unsigned long previous_millis = 0;
char serialData;
myservo.attach(12);
u8g.setRot180();
void draw(int distance) {
u8g.setFont(u8g_font_fur30);
u8g.setPrintPos(0, 63);
u8g.print(distance);
u8g.print("cm");
pinMode(s0, OUTPUT);
pinMode(s1, OUTPUT);
pinMode(s2, OUTPUT);
pinMode(s3, OUTPUT);
pinMode(sensorOut, INPUT);
digitalWrite(s1,LOW);
digitalWrite(s0,HIGH);
pinMode(motor_aPin1,OUTPUT);
pinMode(motor_aPin2,OUTPUT);
pinMode(motor_bPin1,OUTPUT);
pinMode(motor_bPin2,OUTPUT);
pinMode(motor_aEnable,OUTPUT);
pinMode(motor_bEnable,OUTPUT);
analogWrite(motor_aEnable,255);
analogWrite(motor_bEnable,255);
void brake()
digitalWrite(motor_aPin1,LOW);
digitalWrite(motor_aPin2,LOW);
digitalWrite(motor_bPin1,LOW);
digitalWrite(motor_bPin2,LOW);
void forward()
digitalWrite(motor_aPin2,HIGH);
digitalWrite(motor_bPin2,HIGH);
void forward_left()
void forward_right()
void backward()
digitalWrite(motor_aPin1,HIGH);
digitalWrite(motor_bPin1,HIGH);
void backward_right()
void backward_left()
void left()
void right()
int range(int pos)
myservo.write(pos);
delay(300);
current_distance = sonar1.ping_cm();
if(current_distance==0)
current_distance=100;
if(current_distance > 0 && current_distance < 15){
Serial.print("B");
if(pos==90){
backward();delay(500);}
if(pos < 90){
backward_right();delay(500);}
if(pos > 90){
backward_left();delay(500);}
return current_distance;
int dist = sonar1.ping_cm();
u8g.firstPage();
do {
draw(dist);
while (u8g.nextPage());
delay(100);
Automatic: brake();
delay(300);
while(1){
if(Serial.available()>0)
serialData=Serial.read();
if(serialData=='M')
goto Manual;
above: range90=0;
range90=range(90);
delay(10);
while(range90 >= OB_range ){
if(millis()-previous_millis>2000){
previous_millis=millis();
range(180);
delay(50);
range(0);
delay(50);}
range90=range(90);
analogWrite(motor_aEnable,150);
analogWrite(motor_bEnable,150);
forward(); Serial.print("F");
if(serialData=='M')
goto Manual;
brake();
if(range90 <OB_range)
analogWrite(motor_aEnable,100);
analogWrite(motor_bEnable,100);
brake();
range60=0;
range60=range(60);
delay(200);
range120=0;
range120=range(120);
delay(200);
if(serialData=='M')
goto Manual;
if(range60 >OB_range || range120 >OB_range )
if(range60 >= range120){
forward_right();Serial.print("R");
delay(50);goto above;}
else if(range60 < range120){
forward_left();Serial.print("L");
if(range60 <OB_range && range120 <OB_range)
above1: range30=0;
range30=range(30);
delay(200);
range150=0;
range150=range(150);
delay(200);
if(serialData=='M')
goto Manual;
if(range30 >OB_range || range150 >OB_range )
if(range30 >= range150){
delay(100);goto above;}
else if(range30 < range150){
if(range30 <OB_range && range150 <OB_range)
range0=0;
range0=range(0);
delay(200);
range180=0;
range180=range(180);
delay(200);
if(serialData=='M')
goto Manual;
if(range0 >OB_range || range180 >OB_range )
if(range0 >= range180){
backward_right();Serial.print("R");
delay(200);goto above;}
else if(range0 < range180){
backward_left();Serial.print("L");
if(range0 <OB_range && range180 <OB_range)
backward();Serial.print("B");
delay(200);
goto above1;
Manual: brake();
delay(300);
while(1){
if(serialData=='A')
goto Automatic;
if(serialData=='F')
forward();
if(serialData=='B')
backward();
if(serialData=='S')
brake();
if(serialData=='L')
left();
if(serialData=='R')
right();
