Hallo All,
I have just bought my first ARDUINO UNO three days ago…nothing to say.
NICE JOB, GUYS!
I just have a little suggestion: look at the ARDUINO UNO lay-out of the upper row, the one with the digital out pins.
Well, the step for the all row is NOT 2,54 mm!! (See picture attached)
So, if I have a complete connector of 17 pins (16 connected and one left in the middle of the two female connectors placed on the board) I cannot connect it to the board! This means that I have to cut my piggyback board, and split it in two pieces. Not so nice :~
The bottom one is ok.
And while we're slagging the Arduino design, what's with that massive USB connector? Everyone else uses the nice little mini-B version. And that's not a compatability issue, you can just buy another cable.
And the lack of a easy to enable/disable automatic board reset via DTR signal. Over complex/designed auto voltage switching Vs simple manual switch or jumper.
All these have been discussed forever on this forum, so it's a bit old in the tooth. Plus one can always choose 3rd party boards that correct or improve some or all these 'problem areas'. Still all in all the Arduino platform has seemed to have become the dominate hobbyist platform at this time inspite all it's 'flaws', so many of us have tired of the subject and have moved on. ;)
Not sure I'm too impressed with the new Uno board with all it's various bootloader bugs to date, ceramic resonator Vs crystal, SMD Uno model without the removable 328 chip, but then again I don't have to buy one do I?
that only works if the shopper is aware of the issues to begin with, and will only have an effect if everybody does it, and unless people are informed about the problem, nobody is going to actually actively avoid the Uno.
I like seeing people complain about these problems, it shows awareness.
