***LCD-11059-007/111 datasheet and compatible with arduino?***
I’m trying to connect a Blackberry 8520 LCD screen with my Arduino Uno but I don’t know if its compatible as the pins aren’t very user friendly (in the atachment). If is is possible would someone pleae be king enough to find me the datasheet for :‘LCD-11059-007/111’ because I have tried my best but unfortunately could not find one. Some help would be much appreciated. :slight_smile:
It is most likely an OEM part.
So does that mean they're not user friendly or hard to reuse in projects?
rex5511: So does that mean they're not user friendly or hard to reuse in projects?
It means you'd need to contact Blackberry's product development group for documentation on the part and most likely you will have to write your own Arduino library.
Puedes revisar en el sitio que te dejo abajo: el tema trata de un FlashFlex Microcontroller Control of Character LCD Module, que permite conectar la LCD de acuerdo con su hoja de datos. puede ser que te sirva.
http://www.datasheetarchive.com/pdf/download.php?id=7d392fd77dd07cbcc52a2c8c077d60a0504134&type=P&query=LCD+interfacing+to+8051&manufacturer=&part=
