I have connected according to datasheet and glcd-v3 manual, except that the display have no R/W pin.
The datasheet shows a R/W pin in the timing characteristics and in command list so I am a little confused here.
All I got when running GLCDDemo is a little flickering when the program runs.
I no longer maintain the glcd library but have created a newer library openGLCD.
It can be found here: bperrybap / openGLCD / wiki / Home — Bitbucket
It is licensed GPLv3.
It is a superset of the glcd library with bug fixes, and many new features.
If interested, read the wiki and then the html documentation.
You need to see if you can find a better data sheet to help clarify the
pins. As is common in these datasheets, this data sheet has errors in it.
The pinout on pages 4 and 8 don't agree, and both are wrong.
There must be at least a r/w pin for 68 series mode and both read and write
pins for 80 series mode.
Did the vendor give you this datasheet?
You might try googling for the part number on the back of the board.
Getting the correct pinout information is critical as hooking up wires
incorrectly can potentially damage the glcd or the Arduino.
If you can find a better datasheet I can help you get it up and running on openGLCD.
The table in page 8 is true, pin 11 and 18 is NC.
When looking at the back of the PCB the chip is marked (GND)78 - the R/W pin on the chip is pin 77, but the pin left of pin 78 is pin 76 = E, so R/W must be grounded and the module is write only.
In terms of that referenced library mentioning "write only".
A library can choose to use a frame buffer and never read data from the display.
That doesn't necessarily mean that the module is write only.
For example, the u8glib library operates in "write only" mode
but it still does reads when interfacing to displays like ks0108 and sed1520 to check for ready status.
openGLCD has a read cache mode where it will never read data from the display,
however, it will still read the status from the display to be able to tell when
it can send data & commands to the display.
Are you saying that traces just to the left of each of the labeled fat
ground pin 78 traces are the E signals and go to glcd module pins 6 an 7?
Can you show a photo of the other side of the board?
On the other side are there no traces running to glcd module pins 11 and 18?
If so, there doesn't seem to be enough pins.
With motorola mode (68 series) you need a r/w pin and a strobe.
With intel mode (80 series) you need a read strobe and a write strobe.
Motorola mode could work if the r/w pin was grounded but then
you could never read the status register to know when commands
have completed.
There would be no way to run Intel mode since the write stobe pin
is stuck grounded.
It seems very odd that the module would leave two pins (11 & 18) not connected
to anything and hard wire the r/w(WR) pin to ground.
If the module has the r/w(WR) pin hardwired to ground,
openGLCD will not work with the module "as is" since the library
wants to read the status register to know when the module is ready
to receive data/commands.
Without this, the code would have to be changed to use blind delays instead
which requires code changes.
Also, I have no idea how long those delays need to be.
Some of the sed1520 displays can work ok at room temperature
when the Vo signal is left unconnected or connected to ground.
How is your pot wired up?
It looks like it only has two wires going to it which won't allow any adjustment.
I also only see 1 voltage supply so no negative voltage which the link said was required
for the contrast circuit.
I bring all this up because the contrast circuit looks odd in the photo.
Do you get any contrast variation when you adjust the pot?
Am I missing something?
BTW, that demo is a GLCDv3 demo running openGLCD in GLCDv3 emulation mode.
Now with a better power source there is no problems, so it must be a weak connection in the breadboard that coursed problems while starting the display.
