LCD 16*2 doesn't work when code joined with ACS712 sensor
Hello!
I'm working project about Telemetry Street Lamp. Using ACS712 for current sensor(AC current) and Rectifier for voltage sensor (and LCD i2c for interface), when i test each code, it work properly but when i joined current sensor code and LCD code. LCD not show the character.
ACS712 code
#include <Filters.h>
float testFrequency = 60;                     // test signal frequency (Hz)
float windowLength = 20.0/testFrequency;     // how long to average the signal, for statistist
int sensorValue = 0;
float intercept = -0.1129; // to be adjusted based on calibration testing
float slope = 0.0405; // to be adjusted based on calibration testing
float current_amps; // estimated actual current in amps
unsigned long printPeriod = 1000; // in milliseconds
// Track time in milliseconds since last reading
unsigned long previousMillis = 0;
  Serial.begin( 57600 );    // start the serial port
  RunningStatistics inputStats;                 // create statistics to look at the raw test signal
  inputStats.setWindowSecs( windowLength );
  while( true ) {
    sensorValue = analogRead(A0);  // read the analog in value:
    inputStats.input(sensorValue);  // log to Stats function
    if((unsigned long)(millis() - previousMillis) >= printPeriod) {
      previousMillis = millis();   // update time
      // display current values to the screen
      Serial.print( "\n" );
      // output sigma or variation values associated with the inputValue itsel
      Serial.print( "\tsigma: " ); Serial.print( inputStats.sigma() );
      // convert signal sigma value to current in amps
      current_amps = intercept + slope * inputStats.sigma();
      Serial.print( "\tamps: " ); Serial.print( current_amps );
LCD code
/* http://www.electronoobs.com */
/*-----( Inport library )-----*/
#include <Wire.h>
//i2c pins
LiquidCrystal_I2C lcd(0x3F, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE); //
int volt=0;
int amp=0;
//WE define our LCD 16 columns and 2 rows
lcd.begin(16,2);
lcd.backlight();//Power on the back light
//lcd.backlight(); Power off the back light
//Write your text:
lcd.setCursor(0,0); //we start writing from the first row first column
lcd.print("Tegangan: "); //16 characters poer line
lcd.setCursor(0,1);
lcd.print("Arus: ");
final code
#include <Wire.h>
//i2c pins
int volt = 0;
int amp = 0;
float windowLength = 20.0 / testFrequency;   // how long to average the signal, for statistist
  Serial.begin( 9600 );    // start the serial port
  lcd.begin(16, 2);
  lcd.backlight();
  while ( true ) {
    if ((unsigned long)(millis() - previousMillis) >= printPeriod) {
  lcd.setCursor(0, 0); //we start writing from the first row first column
  lcd.setCursor(0, 1);
  lcd.print("Arus: "); lcd.print(current_amps, 5);
Every advice may helps my problem here
Thanks
The problem is that in your main loop you have a while( true ) construct so the LCD code is never executed. Try commenting out the while ( true ) { statement and its corresponding closing '}' and see if you get any further.
That's great! LCD show the character but sadly my current sensor code doesn't work.
Thanks for help me
Ah. I see. Maybe you get further with the code below.
#include <Wire.h>
//i2c pins
int volt = 0;
int amp = 0;
  lcd.begin(16, 2);
  lcd.backlight();
  while ( true ) {
You could also try putting the following 2 lines in setup() and removing the if (true) statement in the loop().
