lcd 16*2 i2c adafruit menu Help
Hi every one !
I’m looking for a functionnalmenu-submenu for a cat feeder-dryer project ( one more)
at first, yo know, i have to build a functionnal menu.
In a perfect way, i would choose how many lunch per day, weight of food, it’s also displaying date and time.
but doesn’t work :confused: can some one give me a clue with my code ?
#include <Adafruit_MotorShield.h>
    #include <Adafruit_RGBLCDShield.h>
    #include <Wire.h>
    #include "RTClib.h"
    RTC_DS1307 RTC;
    Adafruit_RGBLCDShield lcd = Adafruit_RGBLCDShield();
    #define WHITE 0x7
    /* Horloge */
    const char *tableauDesJours[] = {"Sam", "Dim", "Lun", "Mar", "Merc", "Jeu", "Vend",};
    // define some values used by the panel and buttons
    int lcd_key = 0;
    int spd = 0 ;
    int rep = 0 ;
    // Main menu array
    String mainMenu[5];
    // Main menu default choice
    int mainSwitch = 0;
    // Amount of items in our main menu.
    // Can be found by formula:
    // (Amount_of_items - 1)
    #define mainMenuItems 4
      lcd.begin(0x20, 16, 2);
      Wire.begin();
      RTC.begin();
      lcd.setCursor(0, 0);
      print_date();
      /* repas alarme -dev */
      // if(now.hour() == 17 && now.minute() == 11) {
      //Day of week : 1 pour lundi, 2 pour mardi, ...
      // lcd.print("alarme");
      //Pas d'alarme
      // } else {
      //Serial.println("Pas d'alarme");
      /* horloge et calendrier */
      // Filling our main menu items
      mainMenu[0] = "eau & croq    ";
      mainMenu[1] = "ration + 5 Gr ";
      mainMenu[2] = "ration - 5 Gr ";
      mainMenu[3] = "nbre Repas/24h";
    uint8_t i = 0;
    void ration (byte spd)
      print_date();
      lcd.print("RATION?");
      // Loop for reading buttons
      lcd_key = lcd.readButtons();
      switch (lcd_key)
        case (BUTTON_SELECT):
          if (spd = 1)
            lcd.print ("Action valide");
            lcd.print ("ration + 5Gr");
          else if (spd = 2)
            lcd.print ("ration - 5Gr");
        // back to main menu on the left button press
        case (BUTTON_LEFT):
      return;
    void feed()
      print_date();
      lcd.print("CROQ & EAU");
      switch (lcd_key)
        case (BUTTON_UP):
          lcd.print ("feed the beast");
        case (BUTTON_DOWN):
          lcd.print ("niagara");
          break;    // back to main menu on the left button press
        case (BUTTON_LEFT):
      return;
    void Repas()
      print_date();
      lcd.print("MIAM");
      switch (lcd_key)
        case (BUTTON_UP):
          lcd.print ("+1 repas/24H ? ");
          rep = rep + 1;
          lcd.print(rep);
          lcd.print ("repas /24H");
        case (BUTTON_DOWN):
          rep = rep - 1;
          lcd.print(rep);
        case (BUTTON_LEFT):
      return;
    void print_date()
      DateTime now = RTC.now();
      Wire.beginTransmission(0x68); // Accède au RTC I2C d'adresse 0x68.
      Wire.write(0x03); // Pointe le registre du dayOfWeek (0x03).
      Wire.requestFrom(0x68, 1); // Demande de reception d'un octet depuis registre (0x03).
      byte dayOfWeek = Wire.read(); // Stocke la valeur reçue.
      Wire.endTransmission();
      lcd.home();
      String msg_to_print = String(tableauDesJours[dayOfWeek]);
      msg_to_print += " ";
      msg_to_print += String(now.day() / 10, DEC) + String(now.day() % 10, DEC);
      msg_to_print += "/";
      msg_to_print += String(now.month() / 10, DEC) + String(now.month() % 10, DEC);
      msg_to_print += String(now.hour() / 10, DEC) + String(now.hour() % 10, DEC);
      msg_to_print += ":";
      msg_to_print += String(now.minute() / 10, DEC) + String(now.minute() % 10, DEC);
      lcd.print(msg_to_print);
      lcd.setCursor(0, 1);
    // Main loop
  switch (lcd_key)
        case (BUTTON_LEFT):
          print_date();
          lcd.print("     test      ");
        // Enter a sub menu on Right button press
        case (BUTTON_RIGHT):
         switch (mainSwitch) {
        case 0:
          feed();
        case 1:
          ration (spd);
        case 2:
          ration (spd);
        case 3:
          Repas();
        // Move to the next sub menu (UP)
        case (BUTTON_UP):
          mainSwitch = (mainSwitch == 0) ? mainMenuItems : mainSwitch - 1;
          lcd.print(mainMenu[mainSwitch]);
          delay(300);
        // Move to the next sub menu (DOWN)
        case (BUTTON_DOWN):
          mainSwitch = (mainSwitch > mainMenuItems - 1) ? mainSwitch = 0 : mainSwitch + 1;
          delay(300);
  1. what is your hardware - pls post your schematic or a self explaining picture of your wiring
  2. switch/case doesn't work with strings - have a look at the syntax that is used for switch/case
Thank’s a lot, during the week, i’ve made some change about the code, with help !
it’s arduino uno rev3, with a dstimer1307,motorshield v2.3 adafruit 1438 and lcd shield adafruit 772 with six buttons.
all is I2C connected.
#include <Adafruit_MCP23017.h>
#include <Wire.h>
#include "RTClib.h"
RTC_DS1307 RTC;
// initialisation des moteurs
Adafruit_MotorShield monShield = Adafruit_MotorShield();      // création de l'objet shield motor V3
Adafruit_DCMotor *moteurCroq = monShield.getMotor(1);         // création de l'objet moteurGauche par pointeur et repérage du numéro
Adafruit_DCMotor *moteurPompe = monShield.getMotor(4);        // création de l'objet moteurDroite par pointeur et repérage du numéro
// les différents états du menu
enum {
  date,
  miam,
  niagara,
  reprep,
  repas1,
  repas2,
  ratrat,
  ration1,
  ration2,
varmen = date; //
Adafruit_RGBLCDShield lcd = Adafruit_RGBLCDShield();      // création de l'objet LCD shield adafruit 772
int     x = 8;                                            // nombre moyen de repas par jour
  "Sam",
  "Dim",
  "Lun",
  "Mar",
  "Merc",
  "Jeu",
  "Vend"
int nour = 5000;                                     // temps en millis pour  5Gr
unsigned long rep = 86400000;                         // pour calcul de la distri auto
unsigned long Depart;
// INITIALISATION
  Wire.begin();                                       // On lance la communication i2c
  Serial.begin(9600);                                 // On lance la communication série
  lcd.begin(0x20, 16, 2);                             // On lance la communication avec l'écran
  lcd.setCursor(0, 0);                                // régle le curseur sur la première ligne première colonne
  RTC.begin();                                        //On lance la communication avec l'horloge
  monShield.begin();                                  //On lance la communication avec le shield
  Depart = millis();                                  // Enregistrement de mon point de départ
  uint8_t i = 0;
  uint8_t lcd_key = lcd.readButtons();
  //   if ((millis() - Depart) >= rep) {                   // si rep ms se sont écoulées
  //   Depart = millis();                                // nouvelle enregistrement du point de départ modification en cours pour la nutrition programmée
  switch (varmen) {                                   // détermination de menu dans lequel on se trouve
    case (date) :
     if (lcd_key)  {
  RTC.adjust(DateTime(__DATE__, __TIME__));
  lcd.home();
      switch (lcd_key) {
        case (BUTTON_UP):                          // dans le cas du bouton haut
          varmen = miam;                           // passer au menu repas
        case (BUTTON_DOWN):                           // dans le cas du bouton bas
          varmen = reprep;                   // passer au menu ration
          // fin du switch/case lcd_key pour varmen == date
      // fin du switch/case lcd_key pour varmen == ratrat
    case (miam) :
      if (lcd_key)  {
        lcd.clear() ;
        lcd.print ("miam miam select");
      switch (lcd_key) {
        case (BUTTON_UP):
          varmen = niagara;
        case (BUTTON_DOWN):
          varmen =  date;
          lcd.print("     MIAM !!!! !");
          moteurCroq->setSpeed(200); //On définit la vitesse de rotation
          moteurCroq->run(FORWARD); //On fait tourner les moteurs
          delay(1000); // pendant 1 seconde
          moteurCroq->run(RELEASE); //Puis on les arrête
          break;    // fin du switch/case lcd_key pour varmen == ratrat
    case (niagara) :
      if (lcd_key)  {
        lcd.print ("  Niagara select  ");
      switch (lcd_key) {
        case (BUTTON_UP):
          varmen = ratrat;
        case (BUTTON_DOWN):
          varmen = miam;
          lcd.clear() ;
          lcd.print("NIAGARA !!!");
          moteurPompe->setSpeed(200); //On définit la vitesse de rotation
          moteurPompe->run(FORWARD); //On fait tourner les moteurs
          delay(5000);
          moteurPompe->run(RELEASE); //Puis on les arrête
      } // fin du switch/case lcd_key pour varmen == niagara
    case (reprep) :
      if (lcd_key)  {
        lcd.print ("+1rep   -1rep");
      switch (lcd_key) {
        case (BUTTON_UP):
          varmen = date;
        case (BUTTON_DOWN):
          varmen = ratrat;
          x = x - 1;
          lcd.clear() ;
          lcd.print (x);
          lcd.print ("repas / J");
        case (BUTTON_LEFT):
          x = x + 1;
          lcd.clear() ;
          lcd.print (x);
      }   // fin du switch/case lcd_key pour varmen == reprep
    case (ratrat) :
      if (lcd_key)  {
        lcd.print ("+5 Gr    -5 Gr");
      switch (lcd_key) {
        case (BUTTON_UP):
          varmen = reprep;
        case (BUTTON_DOWN):
          varmen = niagara;
          lcd.clear() ;
          lcd.print("FAIT - 5Gr !");
          nour = nour - 1000;
        case (BUTTON_LEFT):
          lcd.clear() ;
          lcd.print("FAIT + 5Gr !");
          nour = nour + 1000;
      }      // fin du switch/case lcd_key pour varmen == ratrat
  } // fin du switch/case varmen
} // fin de loop()
Apparently you found the French section and got help, so this thread could be marked as solved?
rpt007:
hi rpt007!
yes, i've found the french section, znd asked them some help or explanation about my bugs.
but, you know,less users ..then i posted here until i found a solution.
so, not solved.
I understand that two post for a same problem could be useless, same if i think it could be seful.
if you think it's beter to close this one, i will.
"It does not work" does not mean much to us :wink: Please describe what you expect and what actually happens.
By the looks of things, I liked your first version a little better. loop() is a lot smaller and hence the code is easier to comprehend.
sterretje:
“It does not work” does not mean much to us :wink: Please describe what you expect and what actually happens.
yes i’ve made a version with more void (for the two motors and the date)
i’d like to explaibn butafetr a reset one press up, “miam miam select” and press select it launch motor_niag
with de +5 Gr and -5gr , the repas increase or decrease,
with +1 -1 rep it goes to “miam miam selet”
i thought there is a mistake in varmen, or some trouble vith the enum list but not clear to me :
#include <Wire.h>
#include "RTClib.h"
RTC_DS1307 RTC;
Adafruit_DCMotor *moteurMiam = monShield.getMotor(1);         // création de l'objet moteurGauche par pointeur et repérage du numéro
enum {
  date,
  miam,
  niagara,
  diner,
  repas1,
  repas2,
  rationner,
  ration1,
  ration2,
varmen = date; //
  "Sam",
  "Dim",
  "Lun",
  "Mar",
  "Merc",
  "Jeu",
  "Vend"
// INITIALISATION
  uint8_t i = 0;
void print_date()
{ DateTime now = RTC.now();
  lcd.home();
void motor_miam()
  moteurMiam->setSpeed(200); //On définit la vitesse de rotation
  moteurMiam->run(FORWARD); //On fait tourner les moteurs
  moteurMiam->run(RELEASE); //Puis on les arrête
void motor_niag()
  lcd.clear() ;
  delay(5000);
    case (date) :
      if (lcd_key)  {
        print_date();
      switch (lcd_key) {
          varmen = diner;                   // passer au menu ration
    case (miam) :
      if (lcd_key)  {
        lcd.clear() ;
      switch (lcd_key) {
        case (BUTTON_UP):
          varmen = niagara;
        case (BUTTON_DOWN):
          varmen =  date;
          motor_miam();
      }   // fin du switch/case lcd_key pour varmen == rationner
    case (niagara) :
      if (lcd_key)  {
      switch (lcd_key) {
        case (BUTTON_UP):
          varmen = rationner;
        case (BUTTON_DOWN):
          varmen = miam;
          motor_niag();
    case (diner) :
      if (lcd_key)  {
      switch (lcd_key) {
        case (BUTTON_UP):
          varmen = date;
        case (BUTTON_DOWN):
          varmen = rationner;
          x = x - 1;
          lcd.clear() ;
          lcd.print (x);
        case (BUTTON_LEFT):
          x = x + 1;
          lcd.clear() ;
          lcd.print (x);
      }   // fin du switch/case lcd_key pour varmen == diner
    case (rationner) :
      if (lcd_key)  {
      switch (lcd_key) {
        case (BUTTON_UP):
          varmen = diner;
        case (BUTTON_DOWN):
          varmen = niagara;
          lcd.clear() ;
          nour = nour - 1000;
        case (BUTTON_LEFT):
          lcd.clear() ;
          nour = nour + 1000;
} // fin de loop()
Can't really help you, but I suspect memory issues as I can't immediately find anything wrong that would explain the behaviour that you describe.
Get rid of String (capital S) in the print_date() function.
void print_date()
  lcd.home();
  char msg_to_print[20];
  sprintf("%s %02d/%02d %02d:%02d", tableauDesJours[dayOfWeek], now.day(), now.month(), now.hour(), now.minute());
Not compiled, not tested.
When you compile, how much memory (code and sram) is reported to be used?
35% with your advice, 41 without
edit 1 : code not workin and too complex for my little brain !!
thank’s for all, found what’s gone wrong so i share the code :slight_smile:
#include <Wire.h>
#include "RTClib.h"
RTC_DS1307 RTC;
enum {
  date,
  miam,
  niagara,
  diner,
  repas1,
  repas2,
  rationner,
  ration1,
  ration2,
varmen = date; //
  "Sam",
  "Dim",
  "Lun",
  "Mar",
  "Merc",
  "Jeu",
  "Vend"
// INITIALISATION
  uint8_t i = 0;
void print_date()
  //  RTC.adjust(DateTime(__DATE__, __TIME__));
  lcd.home();
void motor_miam()
  Serial.print("     MIAM !!!! !");
void motor_niag()
  lcd.clear() ;
  Serial.print("NIAGARA !!!");
  delay(5000);
    case (date) :
      if (lcd_key)  {
        print_date();
      switch (lcd_key) {
          lcd.clear() ;
          lcd.print ("miam miam select   ");
          lcd.print ("+1rep   -1rep   ");
    case (miam) :
      if (lcd_key)  {
        lcd.clear() ;
      switch (lcd_key) {
        case (BUTTON_UP):
          varmen = niagara;
        case (BUTTON_DOWN):
          varmen =  date;
          print_date();
          motor_miam();
    case (niagara) :
      if (lcd_key)  {
        Serial.print("    Niagara select ");
      switch (lcd_key) {
        case (BUTTON_UP):
          varmen = rationner;
        case (BUTTON_DOWN):
          varmen = miam;
          lcd.clear() ;
          motor_niag();
    case (diner) :
      if (lcd_key)  {
      switch (lcd_key) {
        case (BUTTON_UP):
          varmen = date;
          print_date();
        case (BUTTON_DOWN):
          varmen = rationner;
          x = x - 1;
          lcd.clear() ;
          lcd.print (x);
        case (BUTTON_LEFT):
          x = x + 1;
          lcd.clear() ;
          lcd.print (x);
    case (rationner) :
      if (lcd_key)  {
      switch (lcd_key) {
        case (BUTTON_UP):
          varmen = diner;
        case (BUTTON_DOWN):
          varmen = niagara;
          lcd.clear() ;
          nour = nour - 1000;
        case (BUTTON_LEFT):
          lcd.clear() ;
          nour = nour + 1000;
} // fin de loop()
