I checked everything twice, only left side work!
anyone have this problem before!
narzan:
Yes, reported quite often here.
Display probably damaged but -
Post your code to be checked.
Thanks Paul__B it's not necessary! it seems damaged Thanks again
This display has two chips ("blobs") driving it, the "master" HD44780 (or clone) control the left side and the "slave", the right.
If there is a connection failure between the two - which seems to happen from time to time - then the right hand side will not display, or display incorrectly.
I do not recall just now whether incorrect initialisation can cause the second chip not to operate, which is why I suggested reviewing the code setup.
I do not recall just now whether incorrect initialisation can cause the second chip not to operate, ....
I don't think so.
Don
I changed everything on that bourd nothing work, the left blob not working
I changed the LCD to new one
