system
April 21, 2013, 4:20pm
1
Hello All,
Is there anybody who has a sample sketch how I can let an user select a character using the up-down buttons like an up-down scrollbar of available characters. By pressing the select button the desired character is displayed and the cursor is moving to the next position on the display to repeat the same procedure?
E.g. Input a mobile number via the up-down buttons.
Thanks in advance,
Erik
Are you only looking to use 0-9, or 0-9 and a-z / A-Z? They are all ascii characters so, you will use either HEX or decimal to cycle throught the characters.
0-9 => 48-57 DEC, 30-39 HEX
A-Z => 65-90 DEC, 41-5A HEX
a-z => 97-122 DEC, 61-7A HEX
Ascii table
Here is a sample of how to use two buttons to cycle through numbers. This code uses an I2C lcd, some tweaking may be required for your lcd.
#include <Wire.h>
LiquidCrystal_I2C lcd(0x20,16,2);
const byte buttonPin1 = 2; // Up button
const byte buttonPin2 = 3; // Down Button
//const int ledPin = 11;
int buttonState1 = 0;
int lastReading1 = 0;
int buttonState2 = 0;
int lastReading2 = 0;
int lastcount =0;
long onTime1=0;
long onTime2=0;
int count = 0;
//pinMode(ledPin, OUTPUT);
pinMode(buttonPin1, INPUT);
pinMode(buttonPin2, INPUT);
lcd.init(); // initialize the lcd
lcd.backlight();
void loop(){
buttonState1 = digitalRead(buttonPin1);
buttonState2 = digitalRead(buttonPin2);
if (buttonState1 == HIGH && lastReading1 == LOW) {
onTime1 = millis();
count++;
if (buttonState2 == HIGH && lastReading2 == LOW) {
onTime2 = millis();
count--;
//held
if (buttonState1 == HIGH && lastReading1 == HIGH) {
if ((millis() - onTime1) > 500 ) {
delay(200);
count++;
lastReading1 = LOW;
if (buttonState2 == HIGH && lastReading2 == HIGH) {
if ((millis() - onTime2) > 500 ) {
delay(200);
count--;
lastReading2 = LOW;
Serial.println(count);
lcd.setCursor(0,0);
//lcd.clear();
if(lastcount < 0 && count >= 0) lcd.clear();
if(lastcount >=10 && count < 10) lcd.clear();
if(lastcount >=100 && count < 100) lcd.clear();
if(lastcount >=1000 && count < 1000) lcd.clear();
lcd.print(count);
//lcd.clear();
lastcount = count;
lastReading1 = buttonState1;
lastReading2 = buttonState2;
system
April 22, 2013, 6:49pm
3
Thank you very much for your reply.
I definitely can do something with your sketch!
Cheers,
Erik
