i used officials libraries LiquidCrystal_I2C and hd44780 (I2Cexpdiag)
backlight is useful but that's all !
And so what did I2CexpDiag show?
Did you try adjusting the pot?
That pot will require many turns to make a difference.
At one end you will see no pixels, at the other, all pixels will always be on.
Somewhere in between the pixels will work as expected.
That is an odd way to solder the backpack. The pin orientation isn't changed, but usually the backpack is soldered so the
backpack doesn't stick up above the LCD PCB.
On that backpack (and I have few them), I replace the pot and relocate it.
--- bill
Did you adjust the contrast with the pot? Out of the box, the contrast is normally set too light to see. Even if the Arduino isn't doing it's job printing to it, on power on you'll see a row of black boxes on the screen that you can use to make sure your contrast is adjusted right.
I2CexpDiag show :
Scanning i2c bus for all lcd displays
LCD at address: 0x20 | config: P65401237L | R/W control: Yes
Total LCD devices found: 1
No working LCD devices
Does the contrast pot work? and vary the contrast?
If not the backpack was soldered on backwards with all the pins reversed.
Can you post a photo of the other side?
I want to take a look to make sure the backpack wasn't soldered backwards.
--- bill
yes contrast pot work.
dvarrel:
So you are saying that when you turn it all the way to one end all the pixels turn off, and all the way to the other end all the pixels are on?
You still have not posted the I2CexpDiag output or a photo of the other side.
--- bill
i2cexpdiag : message #3
i found it : RW pin was not solded proprely
thanks for all
It must be the correct way, look at this Instructable.
Don
16x2 modules commonly have headers at the top left of the display.
Other modules have headers at bottom right.
I suspect that this mkjdz adapter is designed for bottom-right modules.
Whichever style of adapter / module is used, you can stop short-circuits by slipping paper or thin plastic between the two pcbs.
Hey-ho. The OP has got it working now.
David.
