LCD 16x1 only displays firs 8 characters.
I’ve done some searching here, but have not found a resolution.
I’m starting to interface to a Newhaven 16x1 LCD character display. It uses the ST7066U controller which appears to be HD44780 compatible. However I only get the first 8 digits on the display.
Any thoughts?
Code:
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
// set up the LCD’s number of columns and rows:
lcd.begin(16, 1);
// Print a message to the LCD.
lcd.print(“abcdefghijklmnopqrstuvwxyz1234567890ABCDEFGHIJKLMNOPQRSTUVWXYZ”);
// set the cursor to column 0, line 1
// (note: line 1 is the second row, since counting begins with 0):
lcd.setCursor(0, 0);
// print the number of seconds since reset:
// lcd.print(millis()/1000);
delay(100);
void loop() {}
Any thoughts?
Most 16x1 displays are actually configured as 8x2. Use lcd.begin(8,2) and reposition your cursor at the beginning of the second line (called line 1 in their infinite wisdom) to put stuff on the right side of the screen.
Follow the [u]LCD Addressing[/u] link at http://web.alfredstate.edu/weimandn for all the gory details.
Don
That did it. Thanks!
