LCD 16x2 Menu I2C 4 Pages
Hello,
Im trying to make a Menu that has 4 pages using an i2c 16x2 display. Only one button would be used to naviagate through the menues...
Could anyone provide me with what software and a diagram of how am I supposed to wire up the button to the arduino...?
If not where am I supposed to look for help?
Thanks?
(deleted)
spycatcher2k:
Sure - £150 AND I'LL DO IT
or open, read & understand the examples supplied on this web site. You should have a working example in a couple of hours. Were here to help, not do your work for you :wink:
Ok I got an open-source code up and running. How do I wire up the button(s)?
// Example for LCD Keypad Shield from http://www.nuelectronics.com/
// * Modified to use a patched LiquidCrystal library
// * Alternative routine to detect keys
#include <stdio.h>
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 16, 2);
// hardware settings
#define rightKey 0
#define upKey 1
#define downKey 2
#define leftKey 3
#define selectKey 4
#define NUM_KEYS 5
// Program parameters
#define minOpt1 5
#define maxOpt1 999
int valueOpt1 = 15;
#define minOpt2 1
#define maxOpt2 99
int valueOpt2 = 10;
#define programMode1 0
#define programMode2 1
#define programMode3 2
int programMode = programMode1;
boolean inMainProgram = false;
int programmSequence = 0;
#define sequenceModeSelect 0
#define sequenceModeOption 1
#define sequenceModeProgram 2
// first menu line - description of menu level
char sequenceHeader[3][17] = {"Mode select ", "Option select ", "Program start "};
// second menu line - mode select
char sequenceModes[3][17] = {" Mode 1 >", "< Mode 2 >", "< Mode 3 "};
// second menu line - options settings
char sequenceOptions[3][17] = {"Option 1: ", "Option 2: ", "no options "};
// initial lcd display while initialize and pc detection
lcd.begin();
lcd.clear();
lcd.print("Freeduino 0.0.1");
programmSequence = sequenceModeSelect;
delay(2000);
updateScreen();
// main loop with new key detection
int keyEvent = -1;
int lastEvent = -1;
int countEvent = 0;
//Key message
char msgs[5][3] = {
"v ",
void updateScreen()
lcd.clear();
lcd.print(sequenceHeader[programmSequence]);
lcd.setCursor(0,1);
switch(programmSequence)
case sequenceModeSelect:
menuModeSelect( keyEvent );
case sequenceModeOption:
menuOptionSelect( keyEvent );
case sequenceModeProgram:
int keyEvent = detectKey();
if (keyEvent >= 0)
switch (keyEvent)
case upKey:
if (!inMainProgram)
if (programmSequence > sequenceModeSelect)
programmSequence--;
updateScreen();
case downKey:
if (!inMainProgram)
if (programmSequence < sequenceModeProgram)
programmSequence++;
updateScreen();
case rightKey:
case leftKey:
if (!inMainProgram)
switch (programmSequence)
case selectKey:
lcd.setCursor(0, 1);
if (lastEvent != keyEvent)
lastEvent = keyEvent;
countEvent=0;
countEvent++;
lcd.print(msgs[keyEvent]);
lcd.print(countEvent);
// Menu tools
void menuModeSelect( int keyEvent )
switch (keyEvent)
case rightKey:
if (programMode < programMode3)
programMode++;
case leftKey:
if (programMode > programMode1)
programMode--;
lcd.setCursor(0,1);
lcd.print( sequenceModes[programMode] );
void menuOptionSelect( int keyEvent )
char cbuf[4] = " ";
lcd.setCursor(0,1);
lcd.print(sequenceOptions[programMode]);
switch (keyEvent)
case rightKey:
switch (programMode)
case programMode1:
if (valueOpt1 < maxOpt1)
valueOpt1++;
case programMode2:
if (valueOpt2 < maxOpt2)
valueOpt2++;
case leftKey:
case programMode1:
if (valueOpt1 > minOpt1)
valueOpt1--;
case programMode2:
if (valueOpt2 > minOpt2)
valueOpt2--;
switch(programMode)
case programMode1:
lcd.print("<");
lcd.print(" ");
sprintf(cbuf,"%3d",valueOpt1);
lcd.print(cbuf);
lcd.print(">");
lcd.print(" ");
case programMode2:
lcd.print("<");
lcd.print(" ");
sprintf(cbuf,"%2d",valueOpt2);
lcd.print(cbuf);
lcd.print(">");
lcd.print(" ");
// Lcd tools
void clearLine(int line)
lcd.setCursor(0,line);
lcd.print(" ");
// Define a custom char in lcd
int defineCharacter(int ascii, int data) {
int baseAddress = (ascii * 8) + 64;
// baseAddress = 64 | (ascii << 3);
lcd.command(baseAddress);
for (int i = 0; i < 8; i++)
lcd.write(data
lcd.command(128);
return ascii;
// Convert ADC value to key number*
int adc_key_val[NUM_KEYS] ={ 30, 150, 360, 535, 760 };
int get_key(unsigned int input)
* int k;
for (k = 0; k < NUM_KEYS; k++)
if (input < adc_key_val[k])
return k;
if (k >= NUM_KEYS)
k = -1; // No valid key pressed*
* return k;
// new key detection routine, without delays!
int lastKeyEvent = 0;
int curKeyEvent = 0;
int keyToReturn = 0;
boolean keyToProcess = false;
int adc_key_in = 0;
int detectKey()
keyToReturn = -1;
adc_key_in = analogRead(0); // read the value from the sensor
curKeyEvent = get_key(adc_key_in); // convert into key press*
* if (curKeyEvent != lastKeyEvent)
if (!keyToProcess)
lastKeyEvent = curKeyEvent;
keyToProcess = true;
else*
keyToReturn = lastKeyEvent;
lastKeyEvent = -1;
return keyToReturn;
// ===================================================================[/sup]*
Nick Gammon Switches Tutorial
Ok. I figured out 95% of the stuff. Im unsure how would I program the button that after being on the last page that if i press a button it returns to the first page.
Code
void process_display(){
switch (right) {
case 0:
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Volts");
lcd.setCursor(0,1);
lcd.print("Amps");
case 1:
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Analog 1");
lcd.setCursor(0,1);
lcd.print("Value");
case 2:
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Analog 2");
lcd.setCursor(0,1);
lcd.print("Value");
case 3:
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Analog 3");
lcd.setCursor(0,1);
lcd.print("Value");
You need to use Code Tags and post all of your code. See How to use this forum
So I am only guessing that maybe you need something like this, but you didn't post the section it needs to go in.
if (right >3)
  right = 0;
