LCD 16x2 refresh and flow meter
Hello everybody,
First, I’m French and I’m a beginner with arduino (Since this morning !!)
Last week I’ve received my starterkit and a flow meter (hall effect sensor, https://fr.rs-online.com/web/p/indicateurs-interrupteurs-et-capteurs-de-debit/4468315/?searchTerm=446-8315&relevancy-data=636F3D3126696E3D4931384E525353746F636B4E756D6265724D504E266C753D656E266D6D3D6D61746368616C6C26706D3D5E5C647B337D5B5C732D2F255C2E2C5D5C647B332C347D2426706F3D313426736E3D592673743D52535F53544F434B5F4E554D4245522677633D4E4F4E45267573743D3434362D3833313526 )
Today I’ve tried to connect my flow meter and a 16x2 LCD to the arduino UNO. It’s a success and working but I’ve encountered some problems.
Digit on the LCD (value of the flow) are not refresh aright.
Below my code, for you, where is the problem ?
if I’ve understood Arduino’s programming, for me the problem is located in the “void loop” but I don’t see where…
And finally, what do you think about my code ?
YF‐ S201 Water Flow Sensor
Water Flow Sensor output processed to read in litres/hour
Adaptation Courtesy: www.hobbytronics.co.uk
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(7, 6, 8, 9, 10, 11);
volatile int flow_frequency; // Measures flow sensor pulses
unsigned int l_min; // Calculated litres/min
unsigned char flowsensor = 2; // Sensor Input
unsigned long currentTime;
unsigned long cloopTime;
void flow () // Interrupt function
   flow_frequency++;
  lcd.begin(16, 2); // Print a message to the LCD.
   lcd.print("Débitmètre LM");
   lcd.setCursor(9,1);
   lcd.print("l/min");
   pinMode(flowsensor, INPUT);
   digitalWrite(flowsensor, HIGH); // Optional Internal Pull-Up
   attachInterrupt(0, flow, RISING); // Setup Interrupt
   sei(); // Enable interrupts
   currentTime = millis();
   cloopTime = currentTime;
void loop ()
   // Every second, calculate and print litres/min
   if(currentTime >= (cloopTime + 1000))
      cloopTime = currentTime; // Updates cloopTime
      // Pulse frequency (Hz) = 7.5Q, Q is flow rate in L/min.
      l_min = flow_frequency; // (Pulse frequency x 60 min) / 7.5Q = flowrate in L/min
      flow_frequency = 0; // Reset Counter
      Serial.print(l_min, DEC); // Print L/min
      Serial.println(" L/min");
      lcd.setCursor(0,1);
      lcd.print(l_min);
Thx for you response and sorry if my english it’s not the best :wink:
  if(currentTime >= (cloopTime + 1000))will cause a glitch when millis() rolls over back to zero. If you use
if (currentTime - cloopTime >= 1000)the problem will not occur.
What do you mean by not refreshing correctly?
Generally speaking you have to clear whatever is on the display before printing new information, otherwise it gets overlapped. Could this be the issue you're having?
after the "if" add
lcd.clear();
lcd.setCursor(0, 0);
gpop1:
after the "if" add
lcd.clear();
A clear command takes a long time and the screen 'blinks' visibly. Better to fill with spaces
lcd.print("                    ");
lcd.print(l_min);
Or even better, the sprintf function. I'm not 100% sure about the syntax but it should be along the lines of:
char buffer[20]
sprintf(buffer, "Flow rate: %3", l_min);
  lcd.setCursor (0,0);
  lcd.print (buffer);
May God be with you all.
Hello Guys !!
Thanks your quick replies !!
I used
lcd.print(" ");
lcd.print(l_min);
And it’s working good but the complete line is blanking and “l/min” disappear but it’s not a problem.
I have an another question, if I want to connect a second flow meter. Do you think I can use the following code ?
unsigned int l_min2; // Calculated litres/min
unsigned char flowsensor = 2; // Sensor 1 Input
unsigned char flowsensor = 4; // Sensor 2 Input
   flow_frequency++;
   lcd.print("CW Flow"); // CW for Cold water
   lcd.setCursor(0,1);
   lcd.print("HW Flow"); // HW for Hot water
void loop ()
   if (currentTime >= (cloopTime + 1000))
      lcd.setCursor(8,0);
      lcd.print("             ");
      lcd.print(l_min);
      lcd.setCursor(8,1);
      lcd.print("             ");
      lcd.print(l_min2);
      l_min2 = flow_frequency2
      flow_frequency2 = 0;
      Serial.print(l_min2, DEC);
      lcd.setCursor(8,0);
      lcd.print(l_min);
      lcd.setCursor(8,1)
      lcd.print(l_min2)
If you think that my code is too complicated, say it and I will try to make it more simple.
It's my first code and I've not good automation. Have you some books to advise me in order to learn arduino ?
I know there is some tutorials but I prefer to work with books.
Thanks you guys !!
No. You will need two interrupts on two different pins.
//pulse counts changed within count_ISR's
volatile unsigned int count1;
volatile unsigned int count2;
//variables for protected copies of counts
unsigned int copyCount1;
unsigned int copyCount2;
void count1_ISR()
  count1++;
void count2_ISR()
  count2++;
  //send test signal to interrupt pins
  analogWrite(5,127);//980 hz timer 0 jumper pin 5 to pin 2
  analogWrite(9,127);//490 hz timer 2 jumper pin 9 to pin 3
  attachInterrupt(0, count1_ISR, RISING); //pin2 (Atmega328)
  attachInterrupt(1, count2_ISR, RISING); //pin3 (Atmega328)
  static unsigned long lastSecond;
  if (micros() - lastSecond >= 1000000L)
    lastSecond += 1000000;
    getCount();
    Serial.println(copyCount1);
    Serial.println(copyCount2);
unsigned int getCount()
  noInterrupts();
  copyCount1 = count1;
  count1 = 0;
  copyCount2 = count2;
  count2 = 0;
  interrupts();
ivan59200:
Hello Guys !!
I used
lcd.print(" ");
lcd.print(l_min);
  flow_frequency++;
  lcd.print(“CW Flow”); // CW for Cold water
  lcd.setCursor(0,1);
  lcd.print(“HW Flow”); // HW for Hot water
void loop ()
      lcd.setCursor(8,0);
      lcd.print("            “);
      lcd.print(l_min);
      lcd.setCursor(8,1);
      lcd.print(”            ");
      lcd.print(l_min2);
      lcd.setCursor(8,0);
      lcd.print(l_min);
      lcd.setCursor(8,1)
      lcd.print(l_min2)
Regarding the screen this should fix your issue:
lcd.print("L/min:          ")
lcd.setCursor(8, 0);
lcd.print(l_min);
How it works:
Your basically cleaning the screen by writing the full 16 characters with text on line 0.
lcd.print(l_min);
Now you write the value from the flowmeter, but you command the lcd to start writting on line 0, character 8. So the text "L/min: " stays on screen.
Regarding the flow-meter, depends how fast your pulses are.
If they are slow and you have no delay functions on your code you can poll them.
If they are fast or you have delays in your code, you should use an interrupt. There are 3 available from the UNO. Int 0 (D2), Int 1 (D3) and ICP1 (D8).
If they are very fast (>1Khz), only the ICP1 should be used, in conjunction with timer 1. This is useful for frequency or RPM measurement (in general flowmeters are not that fast)
The code/tips from cattledog should be a good start
