LCD 16x2 + sensor = problem at indicating distance
I'm currently working at a project which involves 2 ultrasonic sensors and one lcd.
However i have encounter a problem.
the system works like this.
I have 2 sensors. One of them is indicating distance on a horizontal position and the other on a vertical position. So my lcd shows the followint measurements:
1: Distance cm:100 row 1 only for distance
2: Height cm:100 row 2 only for height
I've implemented some errors and mesages within the code so it shows out of range stuff... After ever out o range message i used a lcd.clear() command.
This works well if i want to refresh the entire lcd. But sometimes I don't... like in the next case...
For instance if it measeures 9cm (or one digit value) and it rewriting anther one digit value it's ok
If i measure 25cm and the next value is 7, it shows 75.
So if the distance decreases, the las digit won't dissapear.
In this case I either want for that las digit to disappear if it measures from 3 digits to 2,
or refresh only that line, or show more decimals after the number (ex: 9.23 or event 9.00)
Here is the code:
// Start distance measurement for ground
  long duration2, distance2;
  digitalWrite(trig2Pin, LOW);
  delayMicroseconds(2);
  digitalWrite(trig2Pin, HIGH);
  delayMicroseconds(0.50);
  duration2 = pulseIn(echo2Pin, HIGH);
  distance2 = ((duration2 / 2) / 28.7);// * 10;
  if (distance2 < 10) {
    digitalWrite(laserPin, LOW);
    lcd.setCursor(0, 1);
    lcd.print(" LASER INACTIVE ");
    delay(700);
    lcd.clear();
  }    else    {
    lcd.print("Height   cm:");
    lcd.setCursor(12, 1);
    lcd.print(distance2);
    delay(700);
Any suggestions?
I don't think i can.
That's because I've alocated the las 4 digits of a row to measurement values.
so it lookx like this:
XXXXXXXXXXXX1234
let's say we make a measurement:
XXXXXXXXXXXX12XX = 12cm
XXXXXXXXXXXX100X = 100cm
XXXXXXXXXXXX120X = 12cm again!
So that's th part of the variable value that changes from 4 to 2 or 1 to 3 digits.
If there is no other way... i'll just use the float :frowning:
I don't think you are writing 4 digits. You always have to be sure that you write the correct amount of characters to mantain the position.
Here some code I wrote to do that in my RF Power meter. In my program the numbers can change a lot in character length. So every time I write somthing I keep track of how many charcters are written and I use a function to specify the exact amount of characters a number has to occupy.
  • Display the maximum power
    void displayMaxPower ()
    lcd.home();
    if (power_notconnected)
    lcd.print("Maximum power: ");
    lcd.setCursor(0, 1); // goto next line
    lcd.print("INPUT TOO LOW/NC");
    byte chars = printFormattedNumber(max_dbm + currentAttenuation(), 1, 1, true, true);
    chars += lcd.print("dBm ");
    chars += printPowerWatts(convertDbmToMilliWatt(max_dbm + currentAttenuation()));
    filloutLine(chars);
  • Print power in uW, mW or W.
    byte printPowerWatts(float mw)
    byte chars = 0;
    if (mw < 1.0) // If less then 1mW diaplay in uW
    chars = printFormattedNumber(mw * 1000.0, 1, 0, false, false);
    chars += lcd.print("uW");
    else if (mw >= 1000.0) // If more than 1000mW display in W
    chars = printFormattedNumber(mw / 1000.0, 1, 1, false, false);
    chars += lcd.print("W");
    chars = printFormattedNumber(mw, 1, 1, false, false);
    chars += lcd.print("mW");
    return chars;
  • Fillout a complete display line with spaces.
    void filloutLine(byte charsWritten)
    for (byte i=0; i < 16 - charsWritten;i++)
    lcd.print(" ");
  • Print a number with a specific amount of digits and decimals on the display.
  • It is also possible to print a space when there is no negative sign.
  • number: Number to display
  • minAmountDigits: The minimum amount of digits to display. If number is shorter then '0's will be printed before the number.
  • amountDecimals: The amount of decimals to display.
  • fillout: If the amount of decimals is shorter then the desired amount, spaces will be used to get the same string length.
    byte printFormattedNumber(float number, byte minAmountDigits, byte amountDecimals, bool reserveMinus, bool fillout)
    byte chars = 0; // Number of chars written.
// If no minus sign, write a space
if (reserveMinus && number >= 0)
chars += lcd.print(" ");
else if (number < 0)
chars += lcd.print("-");
//Print integer part. When current value has less digits then wanted add extra zero's
int digitPart = (int)number;
byte digitCount = getAmountDigits(digitPart);
if (digitCount < minAmountDigits)
for (byte i=0; i < minAmountDigits - digitCount; i++)
chars += lcd.print("0");
// Display digit part
chars += lcd.print(abs((int)number));
// Display decimal part
if (amountDecimals > 0)
chars += lcd.print(".");
chars += lcd.print(getDecimalPart(number, amountDecimals));
if (fillout)
// Fill missing chars according to desired length
byte totalCharsWanted = minAmountDigits + amountDecimals;
if (reserveMinus)
totalCharsWanted++;
for (byte i=0; i < totalCharsWanted - chars; i++)
return chars; // return the amount of chars written to the display
  • Get the decimal part of a number.
  • 123.56 returns 56
    unsigned int getDecimalPart(float number, int amountDecimals)
    if (number < 0)
    number = -number;
float fract = number - floor(number);
return (unsigned int)(fract * pow(10, amountDecimals));
  • Get amount of digits of an integer.
  • Simple but fast
    byte getAmountDigits(int n)
    n = abs(n);
    if (n < 10) return 1;
    if (n < 100) return 2;
    if (n < 1000) return 3;
you have to pad the printed value with spaces before the value:
  1cm
 10cm
100cm
look into sprintf() and its associated format specifiers to produce a front padded printable value.
or, do the math in a function and pad it with spaces
Adding leading spaces for formatting. I have done the same for floats. Simple.
I also did a version for negative numbest. Season to taste.
int counter = 0;              // setup for example. Variable to print.
void loop()  {
lcd.setCursor(12, 0);         // set cursor position
intSpaceLCD(counter);         // pass integer to print, routine adds leading spaces
lcd.print(counter);           // or put print in function. see below
counter=abs(counter*2+1);     // change number to demonstrate different size numbers
void intSpaceLCD (int aNumber) {
if ((aNumber >=10000) && (aNumber <100000)) { lcd.print(" ");}
if ((aNumber >=1000) && (aNumber <10000))  { lcd.print("  ");}
if ((aNumber >=100) && (aNumber < 1000))  { lcd.print("   ");}
if ((aNumber >=10) && (aNumber < 100))  { lcd.print("    ");}
if ((aNumber >= 0 ) && (aNumber < 10)) { lcd.print("     ");}
// lcd.print(aNumber);         // optional place for print. Prints number passed to function.
