Hi
I want to use Nokia LCD instead 16x2 LCD, this is original program
#include <LiquidCrystal.h>
LiquidCrystal lcd(PA0, PA1, PA2, PA3, PA4, PA5);
const int sensorIn = PA7;
int mVperAmp = 2400; // use 100 for 20A Module and 66 for 30A Module
double Voltage = 0;
double VRMS = 0;
double AmpsRMS = 0;
void setup(){
lcd.begin(16, 2);
void loop(){
Voltage = getVPP();
VRMS = (Voltage/2.0) *0.707; //root 2 is 0.707
AmpsRMS = (VRMS * 1000)/mVperAmp;
Serial.print(AmpsRMS);
Serial.println(" Amps RMS");
lcd.setCursor(0, 1);
lcd.print("U=");
lcd.print(AmpsRMS);
float getVPP()
float result;
int readValue; //value read from the sensor
int maxValue = 0; // store max value here
//int minValue = 1024; // store min value here, 4095.0
int minValue = 4095.0;
uint32_t start_time = millis();
while((millis()-start_time) < 100) //sample for 1 Sec
readValue = analogRead(sensorIn);
// see if you have a new maxValue
if (readValue > maxValue)
/*record the maximum sensor value*/
maxValue = readValue;
if (readValue < minValue)
/*record the minimum sensor value*/
minValue = readValue;
// Subtract min from max
result = ((maxValue - minValue) * 5.0)/1024.0;
return result;
and modified
#include <LCD5110_Graph.h> // THE LIBRARY I AM USING IS THIS:
LCD5110 lcd(PA4, PA3, PA2, PA0, PA1);
double Voltage3 = 0;
double VRMS = 0;
double AmpsRMS = 0;
extern unsigned char SmallFont[];
extern unsigned char MediumNumbers[];
extern uint8_t ui[];
String voltageString3 = "0.0";
int stringLength3 = 0;
float UzValue = 0;
float voltage3 = 0.0; //DC3
float vout3 = 0.0;
void setup(){
lcd.InitLCD();
lcd.update();
void loop(){
Voltage3 = getVPP();
VRMS = (Voltage3/2.0) *0.707; //root 2 is 0.707
// lcd.setCursor(0, 1);
// lcd.print("U=");
// lcd.print(AmpsRMS);
lcd.print(voltageString3, 0, 40);
// lcd.print(AmpsRMS, 0, 40);
float getVPP()
float result;
return result;
Nokia screen is blank because I don't know how to link
(AmpsRMS);
with
voltageString3
