LCD 20 X 4 NO TEXT
hello,
this is one of my first try’s with arduino.
I am trying to print a simple text to a LCD display i2c 20 x 4.
But nothing is displaying on the display.
This is the Display i have:
This is the code i found for testing
** Example Arduino sketch for SainSmart I2C LCD Screen 16x2
** based on https://bitbucket.org/celem/sainsmart-i2c-lcd/src/3adf8e0d2443/sainlcdtest.ino
** by
** Edward Comer
** LICENSE: GNU General Public License, version 3 (GPL-3.0)
** This example uses F Malpartida's NewLiquidCrystal library. Obtain from:
** https://bitbucket.org/fmalpartida/new-liquidcrystal
** Modified - Ian Brennan ianbren at hotmail.com 23-10-2012 to support Tutorial posted to Arduino.cc
** Written for and tested with Arduino 1.0
** NOTE: Tested on Arduino Uno whose I2C pins are A4==SDA, A5==SCL
#include <Wire.h>
#include <LCD.h>
#define I2C_ADDR    0x3F // <<----- Add your address here.  Find it from I2C Scanner
#define BACKLIGHT_PIN     3
#define En_pin  2
#define Rw_pin  1
#define Rs_pin  0
#define D4_pin  4
#define D5_pin  5
#define D6_pin  6
#define D7_pin  7
int n = 1;
LiquidCrystal_I2C  lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin);
  lcd.begin (20,4); //  <<----- My LCD was 20x4
// Switch on the backlight
lcd.setBacklightPin(BACKLIGHT_PIN,POSITIVE);
lcd.setBacklight(HIGH);
lcd.home (); // go home
  lcd.print("Hallo");
  // Backlight on/off every 3 seconds
  lcd.setCursor (0,1);        // go to start of 2nd line
  lcd.print("goodbye");
  lcd.setBacklight(LOW);      // Backlight off
  lcd.setBacklight(HIGH);     // Backlight on
  delay(10000);
I found the I2C_ADDR with the i2c_scanner on the arduino website.
Why does it not work
To post a link you need to use the "Insert a link" button. It looks like you used "Insert an image".
Here's a link to the product page.
Here's an image of the display.
(I used right click > Copy image URL.)
And here's the image you attached.
(I used "Copy link address" and pasted in with the "Insert an image" button. I'm not sure how to insert an image when you upload it yourself.)
Geert75:
Did you try the code from the product page?
Geert75:
Geert75:
0x3F is the I2C address? The product page says the default address is 0x20.
I suspect something went wrong when you read the address.
I notice you received a bunch of replies to an earlier post. It doesn't seem very polite to ignore the input you were given.
Hey
hallo DuaneDegn,
the problem is solved, i needed to adjust the brightness of the display.
About the adress, the adress needs to be 0x3F, i tried it with the adress 0x20 and the display freezes.
Geert75:
Thanks for reporting back. I know you're not the first one to have that problem.
