lcd 20x4 problem
I have hooked my LCD up to my Arduino using the guide on: http://arduino.cc/en/Tutorial/LiquidCrystal
but my backlight doesn’t work.
I have a 20x4 lcd 5v 8ma.
here is my interface list:
-1 GND
-2 + 5v
-3 1k resistor to GND
-4 pin 12
-5 pin 11
-6 pin 10
-7 pin 9
-8 pin 8
-9 pin 7
-10 pin 6
-11 pin 5
-12 pin 4
-13 pin 3
-14 pin 2
-15
-16
my code:
  LiquidCrystal Library - Hello World
 Demonstrates the use a 16x2 LCD display.  The LiquidCrystal
 library works with all LCD displays that are compatible with the
 Hitachi HD44780 driver. There are many of them out there, and you
 can usually tell them by the 16-pin interface.
 This sketch prints "Hello World!" to the LCD
 and shows the time.
  The circuit:
 * LCD RS pin to digital pin 12
 * LCD Enable pin to digital pin 11
 * LCD D4 pin to digital pin 5
 * LCD D5 pin to digital pin 4
 * LCD D6 pin to digital pin 3
 * LCD D7 pin to digital pin 2
 * LCD R/W pin to ground
 * 10K resistor:
 * ends to +5V and ground
 * wiper to LCD VO pin (pin 3)
 Library originally added 18 Apr 2008
 by David A. Mellis
 library modified 5 Jul 2009
 by Limor Fried (http://www.ladyada.net)
 example added 9 Jul 2009
 by Tom Igoe
 modified 22 Nov 2010
 by Tom Igoe
 This example code is in the public domain.
 http://www.arduino.cc/en/Tutorial/LiquidCrystal
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  // Print a message to the LCD.
  lcd.print("hello, world!");
  // set the cursor to column 0, line 1
  // (note: line 1 is the second row, since counting begins with 0):
  lcd.setCursor(0, 1);
  // print the number of seconds since reset:
  lcd.print(millis()/1000);
it doesn’t work…
can anyone help me?
The backlight has nothing to do with the LCD controller and hence the LiquidCrystal library or its associated code are irrelevant.
Have you connected pins 15 and 16?
Don
i haven't connected pins 15 and 16
Then why do you expect the backlight to be lit ?
hi,
  lcd.begin(16, 2);
I think you should also change,
lcd.begin(16, 2);
to
lcd.begin(20, 4);
Tom..... :slight_smile:
