LCD 5110 - How to keep the text from moving at each loop
I’ve created a sketch that reads a temperature sensor, and prints the values to the Serial Monitor and to a 5110 LCD screen.
I’ve basically managed to get it to work, but I believe some of my parameters are wrong. However not sure which.
The error: For each loop the bitmap and string that I print on the screen are offset 2-3 pixels to the right. So the first loop the print look good (center of the LCD screen), the second loop the print moves a bit (2-3 pixels) to the right.
I’ve attached two photos. One showing the first loop (when it looks good) and one of the eight loop (moved quite a bit to the right).
I hope someone can help me spot the error… please also help if you find other errors in the code or comments.
// Created: March 2016
// Last updated: XX
// Purpose: Read analog temperature sensor and print information to Nokia 5110 LCD Screen
// TUTORIALS USED:
// LCD5110 start tutorial - https://www.youtube.com/watch?v=ga_1dqGjsbo
// LCD5110 and temperature sensor - https://www.youtube.com/watch?v=ga_1dqGjsbo
// HARDWARE USED:
// Created for the Arduino Uno R3 Board - Datasheet and schematics - https://www.arduino.cc/en/uploads/Main/Arduino_Uno_Rev3-schematic.pdf
// Temperature sensor (TMP36) - Datasheet and schematics - https://www.arduino.cc/en/uploads/Main/TemperatureSensor.pdf
// Nokia 5110 LCD Screen - Datasheet and schematics N/A
// LIBRARIES USED:
// LCD5110_Graph.h - Used to write to the LCD - created by RinkyDink - Manual - http://www.rinkydinkelectronics.com/library.php?id=47
#include <LCD5110_Graph.h> // The library needed to write to the LCD 5110
// It is assumed that the LCD module is connected to
// the following pins
//      SCK  - Pin 3 (LCD module name is CIK)
//      MOSI - Pin 4 (LCD module name is DIN)
//      DC   - Pin 5 (LCD module name is DC)
//      RST  - Pin 7 (LCD module name is RST)
//      CS   - Pin 6 (LCD module name is CE)
LCD5110 lcd(3,4,5,7,6); // Set the PINs used on the Arduino board for the LCD module
extern unsigned char SmallFont[];
extern unsigned char BigNumbers[];
extern uint8_t temperatureIcon[];
extern uint8_t arduino_logo[];
  // setup code here, to run once:
  // LCD SCREEN
  lcd.InitLCD(); // Initialising the LCD
  lcd.setFont(BigNumbers); // Sets the font to use
  // SENSORS
  pinMode(5, INPUT); // Set the input PIN for the temperature sensor
  // SERIAL MONITOR
  // main code here, to run repeatedly:
  int TMP_sensor = analogRead(A5); // Get the raw data from the TMP sensor
  // Setting up the LCD screen
  lcd.clrScr(); // Clear the screen buffer
  lcd.drawBitmap(0,0, temperatureIcon, 84, 48); // Drawing the Temperature icon
  // DEBUG - For writing to serial the raw temperature value from the sensor.
  // Serial.print("Temperature value: ");
  // Serial.print(TMP_sensor);
  // Serial.println();
  // convert the ADC (temperature sensor reading) reading to voltage
  float voltage = (TMP_sensor/1024.0) * 5.0; // The sensor give a value between 0-1024, which equate to a volate between 0 - 5
  // DEBUG - write the converted voltage
  // Serial.print(", Volts: ");
   //Serial.print(voltage);
  // convert the voltage to temperature in degrees
  float temperature = (voltage - 0.5 ) * 100; // Depends on sensor - see DataSheet - This sensor: 10 millivolts = 1 degree Celsius  - As the sensor can indicate negative temperatures, we have to substract 0.5 and multiply with 100 to get the accurate temperature in Celsius
  // Print temperature in degrees C to the Serial Monitor
  Serial.print("Degrees C: ");
  Serial.println(temperature);
  // Convert the float (eg. 1.54321) to string (letters)
  double floatVal=temperature; // set the double (eg. same as float, but used in the code below
  char charVal[4];               //temporarily holds data from vals - the number 4 decides the length
  String stringVal = "";     //data on buff is copied to this string
  dtostrf(floatVal, 4, 1, charVal); // FloatVal, minimum width (unsure of the use), precision = number of decimal points, string
  //convert chararray to string
  for(int i=0;i<sizeof(charVal);i++) // goes to the temperature (eg. 20.5) character by character and constructs the string
    stringVal+=charVal[i];
  Serial.print("stringVal: ");Serial.println(stringVal); //display the string in the Serial Monitor
  // Print temperature in degrees Celsium to the LCD
   lcd.print(stringVal,25,11); // The last two figures tell where to start writing on the screen
   lcd.update();
This is seriously weird, as the icon moves and the screen is cleared every time round. I'm guessing a bit but try:
Comment out the lcd.print(stringval) to see if the icon moves
Comment out the lcd.drawBitmap, to see if the stringval moves.
move the code
to the setup section. It is not animated and dsoesn't need to be printed every time round.
I don't know why you have to make a string anyway. Maybe it has something to do with decimal point with this font.
