LCD and 5 switches
I'm new to this exciting game.
The first project I'm messing around with requires an LCD and 5 switches.
I got the LCD up and running quickly thanks to the info available on the net. I then managed to add a switch.
I tried to move on to 5 switches, this is where I got stuck.
I've read about using multiple resistors to plug multiple switches into one analogue input but I've got available digital inputs I could use (would the digital inputs be the best and easiest way?).
If anyone recommend a method it would be much appreciated.
Arduino Duemilanove 328
It would be the least ambiguous way, and would need the fewest (zero) external components.
Thanks for the quick reply.
I'll have a bit more of a fiddle around. The setup I just tried with one switch, when pressed resets the board. I'm impressed with my skills.
Could somebody point me in the right direction for wiring switches without resistors?
I looked at this:
but I must have gone wrong somewhere (it resets the whole thing when I press the switch).
