I am using LC OLED TFT display 1.3 inch which works only with ST7789 library and I have AdaFruit 12 Bit Analog to Digital Converter, ADS1015. Both LCD and ADS are connected to Nano but not to each other. I want to connect them and print my values to my display. Does anyone know how should I connect them and what should I add to this code to send these values to LCD? I am using this code for ADS1015:
#include<Adafruit_ADS1X15.h>
#include<Wire.h>
Adafruit_ADS1015 ads;
void setup (void){
if (!ads.begin()) {
Serial.println("Failed to initialize ADS.");
while (1);
ads.setGain(GAIN_ONE);
void loop (void){
int16_t adc0;
float volts0;
adc0=ads.readADC_SingleEnded(0);
volts0 = ads.computeVolts(adc0);
Serial.print("AIN0: "); Serial.print(adc0); Serial.print(" "); Serial.print(volts0); Serial.println("V");
Serial.println("");
LCD:
Hi, @eceilgaz
Welcome to the forum.
Please read the post at the start of any forum , entitled "How to use this Forum".
See also FAQ - Arduino Forum for general rules on forum behaviour and etiquette.
Hello,
Welcome to the Arduino Forum.
This guide explains how to get the best out of this forum. Please read and follow the instructions below.
Being new here you might think this is having rules for the sake of rules, but that is not the case. If you don’t follow the guidelines all that happens is there is a long exchange of posts while we try to get you to tell us what we need in order to help you, which is fru…
This will help with advice on how to present your code and problems.
Have you got code for each of the LCD and ADC to prove they work separately?
Thanks.. Tom...
Yes, ADC code is in my question and LCD code is this:
ST7789 240x240 IPS (without CS pin) connections (only 6 wires required):
#01 GND -> GND
#02 VCC -> VCC (3.3V only!)
#03 SCL -> D13/SCK
#04 SDA -> D11/MOSI
#05 RES -> D8 or any digital
#06 DC -> D7 or any digital
#07 BLK -> NC
#define TFT_DC 7
#define TFT_RST 8
#define SCR_WD 240
#define SCR_HT 240
#include <SPI.h>
#include <Adafruit_GFX.h>
#include <Arduino_ST7789_Fast.h>
Arduino_ST7789 lcd = Arduino_ST7789(TFT_DC, TFT_RST);
lcd.init(SCR_WD, SCR_HT);
lcd.fillScreen(BLACK);
delay(5000);
lcd.drawRect(0,0,240,240,RED);
lcd.setTextColor(WHITE);
lcd.setTextSize(2);
lcd.setCursor(30,80);
lcd.println("HELLO");
lcd.setTextSize(6);
lcd.setCursor(100,130);
lcd.println("??");
lcd.setTextColor(BLACK,WHITE);
delay(10000);
lcd.setTextSize(6);
lcd.println("WORLD");
delay(15000);
Google;
how to combine two arduino codes
A schematic of your project would be good too, a hand drawn image would be fine.
Tom...
Okay so with both systems working, look at the Google results I suggested in post #4 .
With them both running in the one code, you should then be able to put the variable from the ADC into the display variable of the LCD.
Tom....
Thank you so much for your help. Do you know the necessary connections between them too?
You do not connect them together to get the LCD to display the ADC value, you do that in your code.
Your code is reading the ADC and storing a value that you at the moment you send to the IDE serial monitor.
Your other code is displaying variables that are in the code.
When you combine the two, then make the LCD display the ADC value.
But first get the two codes to work in the same code without errors, before trying to display ADC values.
Tom....
Thank you really much, have a nice day
system
Closed
November 3, 2022, 11:59am
10
