Good afternoon,
I have a HD44780 LCD and an Arduino Duemilanove 2009, and wanted to try the following.
Arduino ----- to connect only one wire------- lcd
Thus it is impossible to know directly, wanted to know suggestions using integrated, so that that only one wire to connect arduino to send things to the lcd
arduino ------- to connect only one wire-------[Whatever it takes to work] ----- lcd
I have a wireless doorbell and the column burned. So I did some experiments with the led.
the button is touch the doorbell I called Arduino with program turning on and off the LED.
At the doorbell where played music, plug the led and connect and worked turning on and off the LED
Then I managed to raise and lower the intensity of the LED.
Now I wanted to connect the lcd.
I will also investigate the shift but at first glance are percise 3 wires
