LCD assistant question: converting to smallest image possible
I'm trying to convert an image using LCD assistant for my SD1306 OLED 0.96' 128x64 screen display. Every time I convert it, it's all zeros. Is there a smallest size parameter to convert to before getting all zeros?
So, I just watched this tutorial for like 300 time. Not really that many... So this is what I get:
// File generated by LCD Assistant
// http://en.radzio.dxp.pl/bitmap_converter/
const unsigned char satalite [] = {
0x1B, 0x00, 0x12, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
what image are you using? it needs to be a black and white bmp file (based on a quick google search)
Image attached:
There’s your problem… there’s no image! :slight_smile:
LOL. I can’t seem to attach my BMP file.
Let’s try this again. Looking closer at the attachment criteria BMP is not an acceptable file.
Got your image, translated in bitmap. Got LCD assistant, loaded image, saved output. The bmp has a black background.
I get this
const unsigned char satellite1 [] = {
0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F,
0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x3F, 0x1F, 0x0F, 0x07, 0x03, 0x03, 0x03, 0x03,
0x01, 0x03, 0x07, 0x1F, 0x3F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F,
0x3F, 0x1F, 0x0F, 0x07, 0x03, 0x01, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x0F, 0x1F, 0x3F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F,
0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x47, 0x03, 0x01, 0x00,
0x00, 0x00, 0x00, 0x40, 0x40, 0x60, 0x60, 0x70, 0x70, 0x78, 0x79, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F,
0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x3F, 0x0F, 0x03, 0x01,
0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x03, 0x07, 0x07, 0x23, 0x60, 0x70,
0xE0, 0xC0, 0x00, 0x00, 0x00, 0x40, 0x40, 0x60, 0x60, 0x70, 0x70, 0x78, 0x78, 0x7C, 0x7C, 0x7E,
0x7E, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F,
0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0x7F, 0xFF, 0xFF, 0x7F, 0x7F, 0x7F, 0x7F,
0x7F, 0x3F, 0x3F, 0x1F, 0x0F, 0x0F, 0x07, 0x07, 0x8F, 0xBF, 0x7F, 0xBF, 0x38, 0x10, 0x00, 0x00,
0x00, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x80, 0x80, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x80, 0x80, 0x00, 0x00, 0x00, 0x80, 0x00, 0x00, 0x00, 0x41, 0x61, 0xF9, 0xFF, 0xFF,
0x7F, 0xFF, 0x7F, 0x7F, 0x7F, 0xFF, 0xFF, 0xFF, 0x7F, 0x7F, 0x7F, 0x7F, 0xFF, 0x7F, 0xFF, 0xFF,
0xFF, 0x7F, 0x7F, 0xBF, 0x3F, 0x9F, 0x9F, 0x8F, 0x0F, 0x07, 0x87, 0x83, 0x83, 0x01, 0x01, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x00, 0x00, 0x00, 0x80, 0x80, 0x80, 0x0C, 0x9E, 0x86, 0x02,
0x80, 0x00, 0x00, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x00, 0x80, 0x80, 0x80, 0x80, 0x00, 0x80,
0x80, 0x80, 0x80, 0x00, 0x80, 0x40, 0xE0, 0xF0, 0x78, 0x7C, 0xFF, 0x7F, 0xFF, 0xFF, 0xFF, 0x7F,
0x7F, 0x7F, 0xFF, 0xFF, 0x7F, 0x7F, 0xFF, 0x7F, 0x7F, 0x7F, 0x7F, 0xFF, 0x7F, 0x7F, 0x7F, 0x7F,
0x7F, 0x7F, 0xFF, 0x60, 0x40, 0x00, 0x00, 0x00, 0x00, 0x80, 0x00, 0x00, 0x00, 0x80, 0x80, 0x80,
0x00, 0x80, 0x80, 0x00, 0x80, 0x40, 0xE0, 0x60, 0x70, 0xF8, 0xF8, 0x04, 0x00, 0x00, 0x00, 0x80,
0x00, 0x00, 0x00, 0x00, 0x80, 0x00, 0x80, 0x80, 0xC0, 0xC0, 0xC0, 0xE0, 0xC0, 0x00, 0x00, 0x80,
0x9C, 0xFC, 0x7E, 0x7F, 0xFF, 0x7F, 0x7F, 0xFF, 0x7F, 0x7F, 0x7F, 0xFF, 0xFF, 0xFF, 0x7F, 0xFF,
0xFF, 0xFF, 0x7F, 0xFF, 0x7F, 0x7F, 0xFF, 0x7F, 0xFF, 0x7F, 0x7F, 0x7F, 0xFF, 0x7F, 0xFF, 0x7F,
0xFF, 0x7F, 0x7F, 0xFF, 0xFF, 0x7E, 0xF8, 0xE0, 0x80, 0x80, 0x80, 0x40, 0xE0, 0xF0, 0xF0, 0x78,
0x7C, 0x7C, 0x7E, 0x7F, 0xFF, 0x7F, 0xFF, 0xFF, 0x7F, 0x7F, 0x7E, 0x7C, 0xFC, 0x7C, 0xFC, 0x7C,
0x7C, 0x7E, 0xFE, 0xFE, 0x7E, 0xFF, 0xFF, 0x7F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFC, 0xFC,
0xFC, 0xFE, 0x7F, 0xFF, 0xFF, 0x7F, 0x7F, 0x7F, 0x7F, 0xFF, 0xFF, 0x7F, 0xFF, 0x7F, 0x7F, 0x7F,
0x7F, 0x7F, 0x7F, 0xFF, 0xFF, 0xFF, 0x7F, 0xFF, 0x7F, 0xFF, 0xFF, 0xFF, 0xFF, 0x7F, 0x7F, 0xFF,
0xBF, 0x37, 0x47, 0xE7, 0x1F, 0x97, 0x67, 0x47, 0x77, 0x37, 0x47, 0x5F, 0x07, 0xDF, 0x97, 0x8F,
0x7F, 0x37, 0xC7, 0xE7, 0x7F, 0x6F, 0x1F, 0x97, 0x77, 0x97, 0xE7, 0x2F, 0xB7, 0xAF, 0xAF, 0x1F,
0xDF, 0x9F,
If you want white background
const unsigned char satellite2 [] = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x80, 0x00, 0x80, 0x00,
0x80, 0x00, 0x00, 0x80, 0x00, 0x80, 0x00, 0x80, 0x80, 0x00, 0x80, 0x80, 0x00, 0x00, 0x80, 0x00,
0x00, 0x80, 0x00, 0x80, 0x00, 0x00, 0x00, 0x80, 0x80, 0x00, 0x80, 0x80, 0x00, 0x80, 0x00, 0x00,
0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x80, 0x80, 0x00, 0x80, 0x00, 0x00, 0x00,
0x00, 0x00, 0x80, 0x00, 0x80, 0x00, 0x80, 0x00, 0x80, 0x80, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00,
0x80, 0x00, 0x80, 0x00, 0x80, 0x80, 0x00, 0x00, 0x80, 0x80, 0x00, 0x80, 0x80, 0x80, 0x80, 0x00,
0x00, 0x80, 0x80, 0x80, 0x00, 0x80, 0x80, 0x00, 0x00, 0x80, 0x80, 0x80, 0x00, 0x80, 0x00, 0x80,
0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x00, 0x00, 0x00, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80,
0x00, 0x80, 0x00, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x00, 0x80, 0x80, 0x20, 0x60, 0x70,
0xE0, 0xC0, 0x00, 0x80, 0x80, 0x00, 0x00, 0x80, 0x80, 0x80, 0x00, 0x00, 0x00, 0x00, 0x80, 0x00,
0x80, 0x80, 0x80, 0x80, 0x00, 0x80, 0x80, 0x00, 0x80, 0x00, 0x00, 0x00, 0x80, 0x80, 0x80, 0x00,
0x00, 0x80, 0x80, 0x80, 0x00, 0x80, 0x80, 0x80, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x80, 0x80,
0x00, 0x80, 0x80, 0x80, 0x00, 0x00, 0x00, 0x00, 0x80, 0x80, 0x80, 0x80, 0x00, 0x00, 0x80, 0x00,
0x80, 0x80, 0x80, 0x00, 0x00, 0x00, 0x80, 0x00, 0x00, 0x00, 0x80, 0x00, 0x00, 0x80, 0x00, 0x80,
0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x80, 0x80, 0x00, 0x00, 0x80, 0x00, 0x80, 0x00, 0x80, 0x80,
0x80, 0x00, 0x80, 0x80, 0x80, 0x80, 0x80, 0x00, 0x80, 0x00, 0x80, 0x00, 0x80, 0x00, 0x80, 0x80,
0x00, 0x80, 0x00, 0x80, 0x00, 0x80, 0x00, 0x80, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80,
0x00, 0x80, 0x80, 0x00, 0x00, 0x80, 0x00, 0x80, 0x00, 0x80, 0x80, 0x80, 0x8C, 0x1E, 0x86, 0x02,
0x00, 0x00, 0x00, 0x80, 0x00, 0x80, 0x00, 0x00, 0x80, 0x00, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80,
0x80, 0x80, 0x80, 0x00, 0x00, 0x00, 0x80, 0x80, 0x80, 0x80, 0x80, 0x00, 0x00, 0x80, 0x00, 0x00,
0x80, 0x80, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x00, 0x80, 0x00, 0x00, 0x80, 0x80,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x80, 0x80, 0x00, 0x00, 0x80, 0x80, 0x80, 0x00, 0x00,
0x80, 0x80, 0x00, 0x00, 0x00, 0x80, 0x80, 0x80, 0x00, 0x00, 0x80, 0x00, 0x80, 0x00, 0x00, 0x80,
0x00, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x80, 0x80, 0x00, 0x80,
0x80, 0x00, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x00, 0x80, 0x80, 0x00, 0x00, 0x80, 0x80, 0x00,
0x80, 0x80, 0x00, 0x00, 0x00, 0x80, 0x80, 0x80, 0x80, 0x00, 0x80, 0x80, 0x00, 0x80, 0x80, 0x00,
0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x00, 0x80, 0x80, 0x80, 0x00, 0x00, 0x80, 0x00, 0x00, 0x80,
0x00, 0x80, 0x80, 0x00, 0x80, 0x00, 0x80, 0x80, 0x00, 0x80, 0x80, 0x00, 0x80, 0x00, 0x80, 0x00,
0x00, 0x80, 0x80, 0x80, 0x80, 0x00, 0x80, 0x80, 0x80, 0x80, 0x00, 0x00, 0x80, 0x80, 0x80, 0x80,
0x80, 0x00, 0x00, 0x80, 0x80, 0x80, 0x80, 0x80, 0x00, 0x00, 0x80, 0x00, 0x00, 0x00, 0x80, 0x00,
0x80, 0x80, 0x80, 0x80, 0x00, 0x00, 0x80, 0x80, 0x80, 0x80, 0x00, 0x00, 0x00, 0x80, 0x00, 0x80,
0xA0, 0x78, 0x40, 0x98, 0x60, 0x48, 0xE0, 0x30, 0xF8, 0x58, 0x38, 0x60, 0x88, 0xE8, 0xD8, 0xE8,
0x30, 0x50, 0x78, 0xA8, 0xD0, 0x30, 0xD0, 0xB8, 0xF8, 0x00, 0x20, 0x88, 0xB0, 0xD8, 0xE0, 0x60,
0x60, 0x70,
