lcd+aurduino+ethernet
in the serial monitor it is showing
connecting....
connection failed can anyone tell me the error
#include <SPI.h>
#include <Ethernet.h>
#include "rgb_lcd.h"
#include <Wire.h>
rgb_lcd lcd;
byte mac[] = { 0x98, 0x4F, 0xEE,0x01, 0x65, 0x4E };
IPAddress ip(192,168,19,170);
char server[] = "192.168.19.171";    // name address for LiyanageGroup (using DNS)
char inString[32]; // string for incoming serial data
int stringPos = 0; // string index counter
boolean startRead = false; // is reading?
// Set the static IP address to use if the DHCP fails to assign
EthernetClient client;
//LiquidCrystal lcd(2, A0, A1, A2, A3, A4, A5);
  while (!Serial) {
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    Ethernet.begin(mac, ip);
  ConnectAndRead();
  lcd.begin(16,2);
  lcd.setCursor(0,1);           // set cursor to column 0, row 1
  lcd.print(" Liyanage Group");
void ConnectAndRead(){
  delay(5000);
  Serial.println("connecting...");
  if (client.connect(server, 80)) {
    Serial.println("connected");
    // Make a HTTP request:
    client.println("GET /read_data.php HTTP/1.1");
    client.println("Host:192.168.19.171");
    client.println("Connection: close");
    client.println();
  else {
    Serial.println("connection failed");
String ReadPage(){
  stringPos = 0;
  memset( &inString, 0, 32 ); //clear inString memory
  while(client.connected()){
    if (client.available()) {
      char c = client.read();
      if (c == '
) { //'<' is our begining character
          startRead = true; //Ready to start reading the part
        }else if(startRead){
          if(c != '#'){ //'>' is our ending character
            inString[stringPos] = c;
            stringPos ++;
          }else{
            //got what we need here! We can disconnect now
            startRead = false;
            client.stop();
            client.flush();
            return inString;
  if(!client.connected()){
    client.stop();
    ConnectAndRead();
  lcd.setCursor(0,0);          // set cursor to column 0, row 0 (the first row)
  lcd.print("Web Value : ");    // change this text to whatever you like. keep it clean.
  lcd.print(ReadPage());    // change this text to whatever you like. keep it clean.
delay(50);
Prudhvi:
Check the network cable between "Ethernet shield" and "router"!
Are both ends of the Ethernet cable connected to their respective devices (Ethernet jack at the Ethernet shield and Ethernet LAN-jack at the router?
