I have an LCD that can take up to 70mA for its backlight circuit. My thinking was to PWM this through an Arduino output connected to a BC547 transistor.
One method might be to connect Led-A to +5V, Led-K to the collector and emitter to ground (base to Arduino through a reasonable base resistor).
Another possibility might be an emitter follower (Collector to +5V, Led-A to emitter, Led-K to ground, base to Arduino).
My question is - which is the better way? Can I skip the base resistor in the emitter follower setup? Will either be more efficient than the other?
No you still need some form of current limiting. 75mA is on the limit of what you can control through a resistor.
As back light diodes are normally in series then you want all the voltage you can get so a common emitter circuit will be better. An emitter follower will lose a Vbe from the supply voltage.
The way I have seen it done and the way I am doing it with my LCD is with a darlington transistor to ground and a 150 ohm resistor to plus 5. A TIP220 is what I use. Vary the resistor depending on your current requirements.
