I have got an 16X2 LCD HD44780 form Spark Fun working that shows a temperature reading. I am using the LCD 4 bit library and it works fine. My question is , how do I turn on backlighting? I believe this is available on pins 15 & 16 from the LCD.
If it's an LED backlight, it almost certainly needs an external current limiting resistor. There's a chance it has one built in, but I wouldn't risk burning out the backlight by just applying power without confirming it.
LCD's also use EL-backlights, which are more difficult to power (they need high voltage, high frequency AC at very tiny current), but I doubt a nice modern purchase from Sparkfun would use that.
Hi - Thanks for the advice. Here are some of the specs from the datasheet.
Can I just connect a resistor and an on off type button between pin 15 and pin 1?
5X8 dots with cursor
Built-in controller (KS0066U or Equivalent)
+5V power supply(Also available for +3.0V)
1/16 duty
BKL to be driven by pin1,pin2,or pin15,pin16,or A,K
