I'm trying to implement a bar graph. The input comes from a voltage source that goes from 0-5v. I want this to occupy a single line on a 16x2 screen. I already know how to interface with the screen, and thats done. The issue comes from where to start...
I read the posts already on bar graphs, but they either don't explain enough or aren't the type I want. I want the line to be blank when 0V and full when 5V.
The input is coming from an analog input. I'm literally lost.
Does this mean you have an LCD display?
Take the reading from the analogue channel, that will be a number between 0 and 1023, on your display you only have 16 characters so divide that number by 64. Then the result is how many fully black characters to write. Do this in a for loop.
If your display supports user defined characters, you might be able to define a set of characters that divide the black block normally used by one character position in 4 (or more) progressively wider blocks, this way you could get a better resolution than the 16 standard chars alone.
