just looking for some debugging suggestions.
I have an 8X2 LCD from sure electronics that generally works fine but occasionally (maybe 1 time in 10?) it comes up blank. I see the line of blocks which generally means it has power but then it blanks.
As far as I know the arduino itself is running and going through its initialization sequence which includes a "hello world" which I don't see. It also clears and writes to the display every 250 ms.
If I reset the arduino I always get the hello world and all is ok. This only happens on power up.
Any ideas or avenues to explore?
void lcdbegin(){ //RUNS ONCE IN SETUP
delay(25); //make sure there's a clear delay for lcd power-on ititialization
lcd.clear();delay(5);
lcd.print("Hi Bill!"); delay(250); lcd.clear(); delay(5);
void updatedisplay(){//RUNS EVERY 250 ms
lcd.clear();
lcd.setCursor(0,0); lcd.print(currentgear);
lcd.setCursor(0,1); lcd.print(revratio);
lcd.setCursor(4,0); lcd.print(int((avgtachrpm+50)/100)*100);//tach
lcd.setCursor(5,1); lcd.print(int(roadspeed+.5)); //speed in kph
