LCD Blinking on second line
Hello guys, I’ve just started playing with arduino + LCD
i’m trying to build a clock + temperature sensor using arduino.
the lcd display is updating every sec, but the problem is that the second line keeps blinking when it refreshes.
anyone could help me solve this?
I’ve made a movie so you know what i’m talking about:
http://flickr.com/photos/pasteler0/2726462259/
the code i’m using is this:
#include <LCD4Bit.h>
LCD4Bit lcd = LCD4Bit(2);
int second=20, minute=10, hour=14, i=0; //start the time on 00:00:00
char buf[12];
int pin = 0; // analog pin
int tempc = 0,tempf=0; // temperature variables
int samples[8]; // variables to make a better precision
int maxi = -100,mini = 100; // to start max/min temperature
  lcd.init();
  pinMode(11,OUTPUT);
  digitalWrite(11,HIGH);
  static unsigned long lastTick = 0; // set up a local variable to hold the last time we moved forward one second
// (static variables are initialized once and keep their values between function calls)
// move forward one second every 1000 milliseconds
        if (millis() - lastTick >= 1000) {
      lastTick = millis();
      second++;
        serialOutput();
        if (second >= 60) {
      minute++;
      second = 0; // reset seconds to zero
        if (minute >=60) {
      hour++;
      minute = 0; // reset minutes to zero
        if (hour >=24) {
      hour=0;
void serialOutput() {
  tempc = ( 5.0 * analogRead(pin) * 100.0) / 1024.0;
  lcd.clear();
  lcd.printIn("Hora: ");
  lcd.printIn(itoa(hour, buf, 10));lcd.printIn(":");
  lcd.printIn(itoa(minute, buf, 10));lcd.printIn(":");
  lcd.printIn(itoa(second, buf, 10));
  lcd.cursorTo(2, 0);
  lcd.printIn("Temp: ");
  lcd.printIn(itoa(tempc, buf, 10));
  tempc = 0;
Replace your lcd.clear() with whatever function returns the cursor to home position without clearing it (I’m guessing lcd.cursorTo(1, 0) would work). Then just overwrite the current characters with your new ones. This should stop the flicker, which I’m thinking results from the delay between when the characters are cleared and the time it takes you to write them back (this is why you see it influencing later characters more significantly).
Note that if your newly printed string is shorter than the previous one, this technique will leave old characters on the screen. You can deal with this by printing extra blank characters (spaces) to overwrite (erase) characters that should no longer be there.
  • Ben
yes, it worked, thanks mate! :smiley:
