Hi everyone i wrote some code i don't know why its not working
#include <LiquidCrystal.h>
int rs = 7;
int e = 8;
int d4 = 9;
int d5 = 10;
int d6 = 11;
int d7 = 12;
LiquidCrystal lcd(rs, e, d4, d5, d6, d7);
int n1;
int n2;
String msg;
lcd.begin(16, 2);
while (Serial.available() == 0) {
n1 = Serial.parseInt();
n2 = Serial.parseInt();
msg = Serial.readStringUntil('\n'); // Read until newline character
Serial.print("Received: ");
Serial.print(n1);
Serial.print(" ");
Serial.print(n2);
Serial.print(" ");
Serial.println(msg);
if (msg == "+") {
int result = n1 + n2;
displayResult("Addition", n1, msg, n2, result);
} else if (msg == "-") {
int result = n1 - n2;
displayResult("Subtraction", n1, msg, n2, result);
} else if (msg == "*") {
int result = n1 * n2;
displayResult("Multiplication", n1, msg, n2, result);
} else if (msg == "/") {
if (n2 != 0) {
float result = (float)n1 / n2;
displayResult("Division", n1, msg, n2, result);
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("Error: Division by 0");
void displayResult(String operation, int operand1, String op, int operand2, float result) {
lcd.clear();
lcd.print(operation);
lcd.setCursor(0, 1);
lcd.print(operand1);
lcd.print(op);
lcd.print(operand2);
lcd.print("=");
lcd.print(result);
delay(2000);
lcd.clear();
Welcome to the forum
hamsi3883:
its not working
More details please
What should it do ?
What does it do ?
Which Arduino are you using ?
What is Line ending set to in the Serial monitor ?
bro I'm just trying to do simple calculator with elegy uno r3 LCD is working when i print something else but when i tried this code its not working
Not the baud rate, the Line ending
hamsi3883:
its no line ending
So is the
ever going to find a Newline character in the input ?
it s just calculator we are just writing numbers and operation sign then its printing on the LCD
like that 3 5 * ----- it will be 3 * 5 =15
what do you mean what does it do ?
You said
hamsi3883:
its not working
So what does it do when you enter numbers or commands ? Is anything printed on the LCD for example or is the calculation wrong ? What ?
yes its shows something when i entered something else but when i tried this code its receives inputs and printing them not he serial monitor not printing them on the LCD
Start by setting the Line ending to New Line in the Serial monitor to avoid the need to wait of the Serial timeout to occur
Are you sure that the baud rate of the sketch and the Serial monitor match ?
Try this code:
int rs = 7;
int e = 8;
int d4 = 9;
int d5 = 10;
int d6 = 11;
int d7 = 12;
int n1;
int n2;
String msg;
lcd.begin(16, 2);
Serial.print(msg[0], HEX); // First digit after last number
Serial.print(" ");
Serial.print(msg[1], HEX); // 2o. digit after last number
Serial.print(" ");
Serial.println(msg[2], HEX);// May be 3o. digit after last number
Serial.print(n1);
Serial.print(" ");
Serial.print(n2);
Serial.print(" ");
if (msg[1] == '+') {
} else if (msg[1] == '-') {
} else if (msg[1] == '*') {
} else if (msg[1] == '/') {
if (n2 != 0) {
lcd.clear();
lcd.clear();
lcd.print(op);
lcd.print("=");
lcd.print(result);
delay(2000);
lcd.clear();
system
Closed
April 26, 2024, 12:54pm
18
