LCD characters moving without command
I was trying to create a digital thermometer using an LCD and a DHT11, but I had a few issues. Hopefully, you could help me with them. One was that my LCD characters were constantly shifting to the left and going off to the screen. This is my code:
#include <LiquidCrystal.h>
#include <DHT.h>
int dhtPin = 7; //Set up DHT11 pin
DHT dht(dhtPin, DHT11);
LiquidCrystal LCD(7, 8, 9, 10, 11, 12); //Create LCD object
  Serial.begin(9600); //Turn on serial port
  LCD.begin(16, 2); //Start LCD
  dht.begin(); //Start DHT11
int convert(int tempInC){
  return((tempInC * 9/5) + 32); //Calculate temperature in farenheit
  int temp = dht.readTemperature();  //Read data off of DHT_11
  int humi = dht.readHumidity();
  Serial.println(" "); //Format text
  LCD.setCursor(0,0); //Set LCD cursor
  LCD.print("Temperature:"); Serial.print("Temperature: ");
  LCD.setCursor(1,0);
  LCD.print(convert(temp)); Serial.print(convert(temp));
  LCD.print(char(223)); Serial.print("°");
  Serial.print(" ");
  LCD.print("F "); Serial.print("F ");
  LCD.print("("); Serial.print("(");             //Print temperature in celsius and farenheit
  LCD.print(temp); Serial.print(temp);
  Serial.print(" ");
  LCD.print("C"); Serial.print("C");
  LCD.print(")"); Serial.println(")");
  delay(250); //Pause briefly
  LCD.print("                "); //Clear line
  LCD.setCursor(0, 1);
  LCD.print("Humidity: "); Serial.print("Humidity: ");
  LCD.print(humi); Serial.print(humi);                     //Print humidity in %
  LCD.print("%"); Serial.println("%");
This is how my LCD screen looked:
LCD screen video
Another problem I had was that my DHT11 is constantly displaying the temperature as 0 C and 32 F, and it is at room temperature. I don't know whether this is a problem with my DHT11 sensor or my code.
If anybody could help me with either of these issues, that would be greatly appreciated. I have tried everything but it is not working.
Have you tried "lcd.clear();" instead of a bunch of spaces? I believe the bunch of spaces are being added to the end. This causing your issue. But I'm accustomed to being wrong, lol.
Thank you for the suggestion. I have tried to do this, but I get an error message that says "exit status 1
invalid use of non-static member function." Is there anything else that might be causing the problem that you could think of?
