LCD CMD table commands (KS0066)
For Wintek and others LCD based on KS0066 controler (could be any other..TEST!):
LCD Commands LCD_DISPLAY_CLEAR = 01 h LCD_RETURN_HOME = 02 h LCD_ENTRY_MODE = 04 h LCD_DISP_ON_OFF = 08 h LCD_SHIFT = 10 h LCD_SET_FUNCTION = 20 h LCD_SET_CG_ADDRESS = 40 h LCD_SET_DD_ADDRESS = 80 h
LCD Command Parameters CMD_CURSOR_INCREASE = 02 h CMD_CURSOR_DECREASE = 00 h CMD_DISPLAY_ON = 04 h CMD_DISPLAY_OFF = 00 h CMD_INTERFACE_8BIT = 10 h CMD_INTERFACE_4BIT = 00 h CMD_TWO_LINES = 08 h CMD_ONE_LINE = 00 h
Example: For turn off and on the display:
LCD_DISPLAY_ON_OFF + CMD_DISPLAY_ON = 0x08 + 0x04 = 0x0C :o
LCD_DISPLAY_ON_OFF + CMD_DISPLAY_OFF =0x08 + 0x00 = 0x08 :o
Best Regards!! Frank
Thanks for sharing. Is this information reliable? I see that the commands are same as those of 44780. Can someone please confirm the compatibility between these two controllers? I've read from many websites about the display errors when using KS0066 controller.
I'm using SGL- VCM1602A, 2X16, 5X8 dots. Anybody has experience in interfacing this LCD module?
Thanks.
